Ga door naar hoofdinhoud
HP Pavilion g7-2023cl Battery Replacement
Wat je nodig hebt
  1. HP Pavilion g7-2023cl Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Shut off your device and disconnect the power cord. Disconnect any external devices connected to the device.
    • Place your finger on the battery lock slider, press toward the center of the laptop to unlock the battery.
    • The lock will make a click sound letting you know that the battery is unlocked.
  2. HP Pavilion g7-2023cl Battery Replacement: stap 2, afbeelding 1 van 3 HP Pavilion g7-2023cl Battery Replacement: stap 2, afbeelding 2 van 3 HP Pavilion g7-2023cl Battery Replacement: stap 2, afbeelding 3 van 3
    • Use your thumb to pry up the edge of the battery and lift it out of the device.
    • When replacing the battery, align the notch on the battery with the battery lock on the device. Gently press down on the battery until you hear the lock click, which signals that the battery is secure.
Conclusie
Thomas Maloney
1.060 Reputatie
9 handleidingen geschreven
UMass Dartmouth, Team S8-G4, Bailey Spring 2019 Lid van UMass Dartmouth, Team S8-G4, Bailey Spring 2019
UMASSD-BAILEY-S19S8G4
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 311
