Ga door naar hoofdinhoud
HP Pavilion g7-1368dx Keyboard Replacement
Wat je nodig hebt
  1. HP Pavilion g7-1368dx Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the device over so that the lower case is facing up.
    • Slide the battery release latch. The battery will pop up.
  2. HP Pavilion g7-1368dx Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Lift and remove the battery from its compartment.
  3. HP Pavilion g7-1368dx Keyboard Replacement, Keyboard: stap 3, afbeelding 1 van 3 HP Pavilion g7-1368dx Keyboard Replacement, Keyboard: stap 3, afbeelding 2 van 3 HP Pavilion g7-1368dx Keyboard Replacement, Keyboard: stap 3, afbeelding 3 van 3
    • Loosen the two Phillips #1 screws that connect the service panel to the device.
    • These are captive screws and cannot be fully removed. They will remain attached to the service panel.
    • Slide the service panel down and pull it up to remove.
  4. HP Pavilion g7-1368dx Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Remove the one 7 mm Phillips #1 screw securing the keyboard to the device.
  5. HP Pavilion g7-1368dx Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Flip over the device and open the screen.
  6. HP Pavilion g7-1368dx Keyboard Replacement: stap 6, afbeelding 1 van 2 HP Pavilion g7-1368dx Keyboard Replacement: stap 6, afbeelding 2 van 2
    • Flip the keyboard over and locate the black ribbon cable that attaches the keyboard to the device.
    • Using a plastic opening tool, flip up the white tab on the zero insertion force connector.
    • Disconnect the ribbon cable by sliding it out of the ZIF connector.
    • Remove the keyboard.
Conclusie
Kianna Young
109 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 285
