Ga door naar hoofdinhoud
HP Pavilion g7-1368dx Hard Drive Replacement
Wat je nodig hebt
  1. HP Pavilion g7-1368dx  Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the device over so that the lower case is facing up.
    • Slide the battery release latch. The battery will pop up.
  2. HP Pavilion g7-1368dx  Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Lift and remove the battery from its compartment.
  3. HP Pavilion g7-1368dx  Hard Drive Replacement, Hard Drive: stap 3, afbeelding 1 van 1
    • Loosen the two Phillips #1 screws that connect the service panel to the device.
    • These are captive screws and cannot be fully removed. They will remain attached to the service panel.
  4. HP Pavilion g7-1368dx  Hard Drive Replacement: stap 4, afbeelding 1 van 1
    • Slide the service panel down and pull it up to remove.
  5. HP Pavilion g7-1368dx  Hard Drive Replacement: stap 5, afbeelding 1 van 2 HP Pavilion g7-1368dx  Hard Drive Replacement: stap 5, afbeelding 2 van 2
    • Locate the hard drive.
    • It is missing from the device pictured here.
    • Disconnect the cable connector by pulling it away from the hard drive.
    • Remove the hard drive from the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Alana Spaeth
570 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 316
