Ga door naar hoofdinhoud
HP Pavilion g7-1365dx WLAN Module Replacement
Wat je nodig hebt
  1. HP Pavilion g7-1365dx WLAN Module Replacement, Battery: stap 1, afbeelding 1 van 1
    • To prevent injury, make sure the laptop is powered off before removing the battery.
    • Flip the laptop so that it is upside down and opens away from you. This exposes the battery, it will be centered at the bottom of the laptop .
    • Push the switch above the battery towards the center of the laptop .
  2. HP Pavilion g7-1365dx WLAN Module Replacement: stap 2, afbeelding 1 van 1
    • While pushing the switch, lift the battery by the side closest to the switch up and away from the laptop.
  3. HP Pavilion g7-1365dx WLAN Module Replacement, Service Door: stap 3, afbeelding 1 van 2 HP Pavilion g7-1365dx WLAN Module Replacement, Service Door: stap 3, afbeelding 2 van 2
    • Using a Phillips size 0 screwdriver, unscrew the 2 Phillips screws.
    • Use the opening tool around the edges of the service door to loosen it and remove it.
  4. HP Pavilion g7-1365dx WLAN Module Replacement, WLAN Module: stap 4, afbeelding 1 van 1
    • Gently pull the black and gray coaxial connectors vertically up off of the module.
    • Make sure to remember which wire was connected to which terminal.
  5. HP Pavilion g7-1365dx WLAN Module Replacement: stap 5, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to take out the 4.7mm screw holding the module.
    • The module is on a spring and will pop out once the screw is taken out.
  6. HP Pavilion g7-1365dx WLAN Module Replacement: stap 6, afbeelding 1 van 1
    • Use your fingers to pull out the WLAN module as shown.
Conclusie
Rafal Szmyd
181 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S1-G1, Simcock Spring 2019 Lid van UMass Dartmouth, Team S1-G1, Simcock Spring 2019
UMASSD-SIMCOCK-S19S1G1
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 11
Altijd: 193
