Ga door naar hoofdinhoud
HP Pavilion g7-1365dx Keyboard Replacement
Wat je nodig hebt
  1. HP Pavilion g7-1365dx Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • To prevent injury, make sure the laptop is powered off before removing the battery.
    • Flip the laptop so that it is upside down and opens away from you. This exposes the battery, it will be centered at the bottom of the laptop .
    • Push the switch above the battery towards the center of the laptop .
  2. HP Pavilion g7-1365dx Keyboard Replacement: stap 2, afbeelding 1 van 1
    • While pushing the switch, lift the battery by the side closest to the switch up and away from the laptop.
  3. HP Pavilion g7-1365dx Keyboard Replacement, Service Door: stap 3, afbeelding 1 van 2 HP Pavilion g7-1365dx Keyboard Replacement, Service Door: stap 3, afbeelding 2 van 2
    • Using a Phillips size 0 screwdriver, unscrew the 2 Phillips screws.
    • Use the opening tool around the edges of the service door to loosen it and remove it.
  4. HP Pavilion g7-1365dx Keyboard Replacement, Keyboard: stap 4, afbeelding 1 van 2 HP Pavilion g7-1365dx Keyboard Replacement, Keyboard: stap 4, afbeelding 2 van 2
    • Remove the 4.7 mm screw that secures the keyboard to the computer using the Philips 00 screwdriver.
  5. HP Pavilion g7-1365dx Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Rest the laptop on its side so the optical drive is pointing up.
    • Insert the hex 2.0 screwdriver into the screw hole that had the 4.7 mm screw, press till the keyboard pops out.
  6. HP Pavilion g7-1365dx Keyboard Replacement: stap 6, afbeelding 1 van 1
    • Turn the laptop right side up, facing you. Use the opening tool to help pull the keyboard towards you.
  7. HP Pavilion g7-1365dx Keyboard Replacement: stap 7, afbeelding 1 van 1
    • Unplug the keyboard ribbon cable and remove the keyboard.
Conclusie
jonathan Rodriguez
109 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team S1-G1, Simcock Spring 2019 Lid van UMass Dartmouth, Team S1-G1, Simcock Spring 2019
UMASSD-SIMCOCK-S19S1G1
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 15
Altijd: 493
