Ga door naar hoofdinhoud
HP Pavilion g6-2228tx Optical Drive Replacement
Wat je nodig hebt
  1. HP Pavilion g6-2228tx Optical Drive Replacement, Battery: stap 1, afbeelding 1 van 2 HP Pavilion g6-2228tx Optical Drive Replacement, Battery: stap 1, afbeelding 2 van 2
    • Push the battery latch to the left to release the battery.
    • Remove the battery from the device.
  2. HP Pavilion g6-2228tx Optical Drive Replacement, Hard Drive: stap 2, afbeelding 1 van 2 HP Pavilion g6-2228tx Optical Drive Replacement, Hard Drive: stap 2, afbeelding 2 van 2
    • Use a Phillips #0 screw driver to loosen the screw. The screw will not detach from the cover.
  3. HP Pavilion g6-2228tx Optical Drive Replacement: stap 3, afbeelding 1 van 3 HP Pavilion g6-2228tx Optical Drive Replacement: stap 3, afbeelding 2 van 3 HP Pavilion g6-2228tx Optical Drive Replacement: stap 3, afbeelding 3 van 3
    • Place your hand on the cover and slide the cover down.
    • Use your hand to lift the cover from the bottom right and slide the cover to the right to remove the cover.
  4. HP Pavilion g6-2228tx Optical Drive Replacement: stap 4, afbeelding 1 van 2 HP Pavilion g6-2228tx Optical Drive Replacement: stap 4, afbeelding 2 van 2
    • Place one finger on the right side of the hard drive.
    • Push the hard drive to the left and lift the hard drive up to remove it from the device.
  5. HP Pavilion g6-2228tx Optical Drive Replacement: stap 5, afbeelding 1 van 2 HP Pavilion g6-2228tx Optical Drive Replacement: stap 5, afbeelding 2 van 2
    • Disconnect the connecting part by pulling the part to the right.
    • Remove the hard drive from the device.
  6. HP Pavilion g6-2228tx Optical Drive Replacement, Optical Drive: stap 6, afbeelding 1 van 2 HP Pavilion g6-2228tx Optical Drive Replacement, Optical Drive: stap 6, afbeelding 2 van 2
    • Remove the 2.5mm screw with a Phillips #0 screw drive.
  7. HP Pavilion g6-2228tx Optical Drive Replacement: stap 7, afbeelding 1 van 3 HP Pavilion g6-2228tx Optical Drive Replacement: stap 7, afbeelding 2 van 3 HP Pavilion g6-2228tx Optical Drive Replacement: stap 7, afbeelding 3 van 3
    • Put one finger into the release hole and push to the left until part of the optical drive comes out from the left of the laptop.
  8. HP Pavilion g6-2228tx Optical Drive Replacement: stap 8, afbeelding 1 van 3 HP Pavilion g6-2228tx Optical Drive Replacement: stap 8, afbeelding 2 van 3 HP Pavilion g6-2228tx Optical Drive Replacement: stap 8, afbeelding 3 van 3
    • Grab the optical drive and pull to the left to remove it from the device.
Conclusie
Hai Lin
446 Reputatie
4 handleidingen geschreven
UC Davis, Team S4-G6, Lore Fall 2018 Lid van UC Davis, Team S4-G6, Lore Fall 2018
UCD-LORE-F18S4G6
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 17
Altijd: 977
