Inleiding
If the CD drive is damaged or needs to be removed to get to another component of the laptop, this is a guide to do so.
Wat je nodig hebt
Flip the computer so the bottom is facing up with the battery away from you.
Loosen the two 5.7 mm screws on the bottom panel using a PH00 screwdriver.
Bijna klaar!
Conclusie
