Ga door naar hoofdinhoud
HP Pavilion dv9000 Wireless Card Replacement
Wat je nodig hebt
  1. HP Pavilion dv9000 Wireless Card Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the laptop over to expose the bottom side.
    • Locate the battery removal switch next to the battery compartment
    • Important: Before doing any repairs on the laptop, make sure it is completely powered down and unplugged.
  2. HP Pavilion dv9000 Wireless Card Replacement, Battery Removal: stap 2, afbeelding 1 van 2 HP Pavilion dv9000 Wireless Card Replacement, Battery Removal: stap 2, afbeelding 2 van 2
    • Slide the switch all the way to the left to release the battery. The battery should pop up.
    • Lift the battery out.
  3. HP Pavilion dv9000 Wireless Card Replacement, Wireless Card: stap 3, afbeelding 1 van 3 HP Pavilion dv9000 Wireless Card Replacement, Wireless Card: stap 3, afbeelding 2 van 3 HP Pavilion dv9000 Wireless Card Replacement, Wireless Card: stap 3, afbeelding 3 van 3
    • Locate the panel that lies in the front center of the laptops underside.
    • Using a Phillips #1 screwdriver, remove the two 5mm screws on the forward end of the cover.
    • Lift off the cover to expose the Wi-Fi card underneath.
  4. HP Pavilion dv9000 Wireless Card Replacement: stap 4, afbeelding 1 van 3 HP Pavilion dv9000 Wireless Card Replacement: stap 4, afbeelding 2 van 3 HP Pavilion dv9000 Wireless Card Replacement: stap 4, afbeelding 3 van 3
    • Locate the Wi-Fi card inside of the computer.
    • With a Phillips #1 screwdriver, remove the two 11mm screws on either side of the wires attached to the top of the Wi-Fi card.
    • Lift the card from its resting location. Be careful, the card and attached wires are fragile.
  5. HP Pavilion dv9000 Wireless Card Replacement: stap 5, afbeelding 1 van 2 HP Pavilion dv9000 Wireless Card Replacement: stap 5, afbeelding 2 van 2
    • Carefully pop the wires off of the Wi-Fi card. They should easily come off with a light tug.
    • As you take each wire off, keep track of the numbered labels. These numbers correspond with contact points on the card.
Conclusie
Erik Hoffnagle
768 Reputatie
3 handleidingen geschreven
Cal Poly, Team 10-32, Maness Winter 2014 Lid van Cal Poly, Team 10-32, Maness Winter 2014
CPSU-MANESS-W14S10G32
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 3,965
