Ga door naar hoofdinhoud
HP Pavilion dv9000 RAM Replacement
Wat je nodig hebt
  1. HP Pavilion dv9000 RAM Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the laptop over to expose the bottom side.
    • Locate the battery removal switch next to the battery compartment
    • Important: Before doing any repairs on the laptop, make sure it is completely powered down and unplugged.
  2. HP Pavilion dv9000 RAM Replacement, Battery Removal: stap 2, afbeelding 1 van 2 HP Pavilion dv9000 RAM Replacement, Battery Removal: stap 2, afbeelding 2 van 2
    • Slide the switch all the way to the left to release the battery. The battery should pop up.
    • Lift the battery out.
  3. HP Pavilion dv9000 RAM Replacement, RAM: stap 3, afbeelding 1 van 3 HP Pavilion dv9000 RAM Replacement, RAM: stap 3, afbeelding 2 van 3 HP Pavilion dv9000 RAM Replacement, RAM: stap 3, afbeelding 3 van 3
    • Locate the middle plastic cover on the bottom of the laptop.
    • Unscrew the two 5mm screws using a Phillips #1 screwdriver. The screws should remain in the plastic cover.
    • Lift and remove the plastic cover.
  4. HP Pavilion dv9000 RAM Replacement: stap 4, afbeelding 1 van 3 HP Pavilion dv9000 RAM Replacement: stap 4, afbeelding 2 van 3 HP Pavilion dv9000 RAM Replacement: stap 4, afbeelding 3 van 3
    • Locate the RAM card and the metal tabs on either side of it.
    • Press both tabs away from the RAM card to release it. The card should flip up towards you.
    • Carefully lift the RAM card out.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Erik Hoffnagle
801 Reputatie
3 handleidingen geschreven
Cal Poly, Team 10-32, Maness Winter 2014 Lid van Cal Poly, Team 10-32, Maness Winter 2014
CPSU-MANESS-W14S10G32
4 Leden
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 34
Altijd: 3,779
