Ga door naar hoofdinhoud
HP Pavilion dv7t-7000 Keyboard Replacement
Wat je nodig hebt
  1. HP Pavilion dv7t-7000 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the computer off and disconnect if from all power sources.
  2. HP Pavilion dv7t-7000 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Slide the battery release switch to the left.
  3. HP Pavilion dv7t-7000 Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Hold the release switch all of the way to the left and your other hand to pull the battery out.
  4. HP Pavilion dv7t-7000 Keyboard Replacement, Back Panel: stap 4, afbeelding 1 van 1
    • Unscrew the single Phillips #00 screw.
    • Screw will not come out, it is connected to the panel
  5. HP Pavilion dv7t-7000 Keyboard Replacement: stap 5, afbeelding 1 van 2 HP Pavilion dv7t-7000 Keyboard Replacement: stap 5, afbeelding 2 van 2
    • Remove service hatch by sliding away from the computer and lifting up.
  6. HP Pavilion dv7t-7000 Keyboard Replacement, Keyboard: stap 6, afbeelding 1 van 2 HP Pavilion dv7t-7000 Keyboard Replacement, Keyboard: stap 6, afbeelding 2 van 2
    • Remove the single Phillips #00 screw.
    • Flip the laptop over.
  7. HP Pavilion dv7t-7000 Keyboard Replacement: stap 7, afbeelding 1 van 3 HP Pavilion dv7t-7000 Keyboard Replacement: stap 7, afbeelding 2 van 3 HP Pavilion dv7t-7000 Keyboard Replacement: stap 7, afbeelding 3 van 3
    • Wedge a spudger in between the keyboard and the upper bezel (nearest the screen).
    • Pry upward to release the keyboard clips.
    • The keyboard is plugged into the motherboard, so be careful not to pull out while lifting keyboard.
  8. HP Pavilion dv7t-7000 Keyboard Replacement: stap 8, afbeelding 1 van 1
    • Use the flat end of a spudger to flip up the black tab on the ZIF connectors.
    • Pull the ribbon cables out of the ZIF connectors.
    • Remove the keyboard.
Conclusie
Gavin Loera
424 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 548
