Ga door naar hoofdinhoud
HP Pavilion dv7-6178us RAM Replacement
  1. HP Pavilion dv7-6178us RAM Replacement, RAM: stap 1, afbeelding 1 van 2 HP Pavilion dv7-6178us RAM Replacement, RAM: stap 1, afbeelding 2 van 2
    • Flip over the laptop and push the sliding lock to the right (or whichever side indicates it with a symbol.)
    • After that is done, carefully pull off the back piece. It should look similar to the second photo.
  2. HP Pavilion dv7-6178us RAM Replacement: stap 2, afbeelding 1 van 1
    • Locate the RAM and push the two tabs on the sides away from the RAM.
  3. HP Pavilion dv7-6178us RAM Replacement: stap 3, afbeelding 1 van 1
    • Once the tabs on the sides are released the RAM card will pop out by itself to this angle, as shown in the picture.
  4. HP Pavilion dv7-6178us RAM Replacement: stap 4, afbeelding 1 van 1
    • Pull the card out of the socket and you have successfully removed one RAM card.
  5. HP Pavilion dv7-6178us RAM Replacement: stap 5, afbeelding 1 van 2 HP Pavilion dv7-6178us RAM Replacement: stap 5, afbeelding 2 van 2
    • Steps 2 through 4 can also be done on the second RAM card, located directly below the initial RAM card.
Conclusie
Branden Simas
178 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team S4-G8, Valliere Fall 2018 Lid van UMass Dartmouth, Team S4-G8, Valliere Fall 2018
UMASSD-VALLIERE-F18S4G8
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 21
Altijd: 605
