Ga door naar hoofdinhoud
HP Pavilion dv7-6178us Hard Drive Replacement
Wat je nodig hebt
  1. HP Pavilion dv7-6178us Hard Drive Replacement, Hard Drive: stap 1, afbeelding 1 van 2 HP Pavilion dv7-6178us Hard Drive Replacement, Hard Drive: stap 1, afbeelding 2 van 2
    • Flip over the laptop and push the sliding lock to the right (or whichever side indicates it with a symbol.)
    • After that is done, carefully pull off the back piece. It should look similar to the second photo.
  2. HP Pavilion dv7-6178us Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Now, with the back piece off, you will remove the four screws holding it in place. Use a Phillips head screwdriver.
    • Take note of where you place the screws because you will need them for later.
  3. HP Pavilion dv7-6178us Hard Drive Replacement: stap 3, afbeelding 1 van 2 HP Pavilion dv7-6178us Hard Drive Replacement: stap 3, afbeelding 2 van 2
    • Place the old hard drive off to the side (as seen in photo) and carefully remove the SATA cable from laptop.
    • Be careful to not damage the laptop or cable when doing this step. A gentle pull should do the trick.
Conclusie
Zach Lunghi
148 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team S4-G8, Valliere Fall 2018 Lid van UMass Dartmouth, Team S4-G8, Valliere Fall 2018
UMASSD-VALLIERE-F18S4G8
4 Leden
6 handleidingen geschreven
Één opmerking
This is a really GREAT thing that's being done!
It's high time that consumers fought back and stop letting the TECHNO-OVERLORDS, collectively STRIP us of the right to use the digital tools that we purchase from them.
Walter D Wormack - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 48
Altijd: 1,760
