Ga door naar hoofdinhoud
HP Pavilion dv7-3065dx RAM Replacement
Wat je nodig hebt
  1. HP Pavilion dv7-3065dx RAM Replacement, Battery: stap 1, afbeelding 1 van 2 HP Pavilion dv7-3065dx RAM Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turn off the device before removing the battery.
    • Place the laptop upside down on a flat surface so that the bottom is facing up.
    • The battery is the long rectangle above the latch.
  2. HP Pavilion dv7-3065dx RAM Replacement: stap 2, afbeelding 1 van 1
    • Slide the battery latch to the left to release the battery.
  3. HP Pavilion dv7-3065dx RAM Replacement: stap 3, afbeelding 1 van 2 HP Pavilion dv7-3065dx RAM Replacement: stap 3, afbeelding 2 van 2
    • Carefully pull out the battery while holding the latch to the open position with your finger.
  4. HP Pavilion dv7-3065dx RAM Replacement, RAM: stap 4, afbeelding 1 van 1
    • Remove the four circled screws using a #1 philips head screwdriver
    • Note: Be sure to leave the screws in the pannel
    • Pry off cover and place to the side.
  5. HP Pavilion dv7-3065dx RAM Replacement: stap 5, afbeelding 1 van 1
    • The RAM modules will be found on the right side of the access panel
    • CAUTION - The RAM modules are sensitive to electrostatic discharge. It is recommended to wear an anti static bracelet while handling the RAM.
  6. HP Pavilion dv7-3065dx RAM Replacement: stap 6, afbeelding 1 van 2 HP Pavilion dv7-3065dx RAM Replacement: stap 6, afbeelding 2 van 2
    • To remove RAM modules, pry metal tabs out of the modules, and pull ram out (Starting from the top RAM module).
    • Note: The RAM Modules pop out away from the motherboard. In order to replace them, slot the gold plated end into the terminal and push down towards the motherboard.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Jonathan Winkler
161 Reputatie
1 Handleiding geschreven
Ohio State, Team 1-5, Wilder Spring 2017 Lid van Ohio State, Team 1-5, Wilder Spring 2017
OSU-WILDER-S17S1G5
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 15
Altijd: 1,261
