Ga door naar hoofdinhoud
HP Pavilion dv7-3065dx Keyboard Replacement
Wat je nodig hebt
  1. HP Pavilion dv7-3065dx Keyboard Replacement, Battery: stap 1, afbeelding 1 van 2 HP Pavilion dv7-3065dx Keyboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turn off the device before removing the battery.
    • Place the laptop upside down on a flat surface so that the bottom is facing up.
    • The battery is the long rectangle above the latch.
  2. HP Pavilion dv7-3065dx Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Slide the battery latch to the left to release the battery.
  3. HP Pavilion dv7-3065dx Keyboard Replacement: stap 3, afbeelding 1 van 2 HP Pavilion dv7-3065dx Keyboard Replacement: stap 3, afbeelding 2 van 2
    • Carefully pull out the battery while holding the latch to the open position with your finger.
  4. HP Pavilion dv7-3065dx Keyboard Replacement, Hard Drive: stap 4, afbeelding 1 van 1
    • Loosen the four screws that secure the hard drive panel with a Phillips head screwdriver.
    • Do not completely remove the screws from the panel.
  5. HP Pavilion dv7-3065dx Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Lift the drive cover to expose the hard drive.
    • This device did not have a physical hard drive to work with.
    • Gently tug on the black tabs located on each end of the hard drive in order to loosen the hard drive from the motherboard.
    • Be careful when working with the hard drive cable.
    • Separate the hard drive from the cable by firmly gripping the hard drive and the black plug.
    • Remove the four Phillips screws that secure the hard drive to its carrier.
    • There are two screws on each side.
    • Lift and remove the hard drive from the metal surrounding its perimeter.
  6. HP Pavilion dv7-3065dx Keyboard Replacement, Keyboard: stap 10, afbeelding 1 van 1
    • Locate these seven screws that fasten the keyboard and switch cover to the computer.
    • Remove these screws
  7. HP Pavilion dv7-3065dx Keyboard Replacement: stap 11, afbeelding 1 van 1
    • Flip over the computer to the upright position and locate the switch cover.
    • Carefully pry the switch cover up until it detaches from the computer.
    • The switch cover is held in with plastic clips. They may break if they are removed too forcefully.
  8. HP Pavilion dv7-3065dx Keyboard Replacement: stap 12, afbeelding 1 van 1
    • Raise the switch cover to expose the speaker assembly.
    • Carefully detach the ribbon cables from the speaker assembly.
    • Locate and remove these four screws from the switch cover.
  9. HP Pavilion dv7-3065dx Keyboard Replacement: stap 13, afbeelding 1 van 2 HP Pavilion dv7-3065dx Keyboard Replacement: stap 13, afbeelding 2 van 2
    • Locate and remove the screws that hold the keyboard to the computer.
    • Lift the keyboard up to expose the keyboard connector.
    • The keyboard connector is the small cord located near the screen of the computer.
  10. HP Pavilion dv7-3065dx Keyboard Replacement: stap 14, afbeelding 1 van 2 HP Pavilion dv7-3065dx Keyboard Replacement: stap 14, afbeelding 2 van 2
    • Disconnect the keyboard connector by unhinging the blue plastic clips and gently pulling the cord.
    • The keyboard can now be removed from the computer.
Conclusie
Nicholas Moore
302 Reputatie
2 handleidingen geschreven
Ohio State, Team 1-5, Wilder Spring 2017 Lid van Ohio State, Team 1-5, Wilder Spring 2017
OSU-WILDER-S17S1G5
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 15
Altijd: 1,814
