Ga door naar hoofdinhoud
HP Pavilion dv7-3065dx Hard Drive Replacement
Wat je nodig hebt
  1. HP Pavilion dv7-3065dx Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 2 HP Pavilion dv7-3065dx Hard Drive Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turn off the device before removing the battery.
    • Place the laptop upside down on a flat surface so that the bottom is facing up.
    • The battery is the long rectangle above the latch.
  2. HP Pavilion dv7-3065dx Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Slide the battery latch to the left to release the battery.
  3. HP Pavilion dv7-3065dx Hard Drive Replacement: stap 3, afbeelding 1 van 2 HP Pavilion dv7-3065dx Hard Drive Replacement: stap 3, afbeelding 2 van 2
    • Carefully pull out the battery while holding the latch to the open position with your finger.
  4. HP Pavilion dv7-3065dx Hard Drive Replacement, Hard Drive: stap 4, afbeelding 1 van 1
    • Loosen the four screws that secure the hard drive panel with a Phillips head screwdriver.
    • Do not completely remove the screws from the panel.
  5. HP Pavilion dv7-3065dx Hard Drive Replacement: stap 5, afbeelding 1 van 1
    • Lift the drive cover to expose the hard drive.
    • This device did not have a physical hard drive to work with.
    • Gently tug on the black tabs located on each end of the hard drive in order to loosen the hard drive from the motherboard.
    • Be careful when working with the hard drive cable.
    • Separate the hard drive from the cable by firmly gripping the hard drive and the black plug.
    • Remove the four Phillips screws that secure the hard drive to its carrier.
    • There are two screws on each side.
    • Lift and remove the hard drive from the metal surrounding its perimeter.
Conclusie
Gabi Marino
157 Reputatie
1 Handleiding geschreven
Ohio State, Team 1-5, Wilder Spring 2017 Lid van Ohio State, Team 1-5, Wilder Spring 2017
OSU-WILDER-S17S1G5
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 17
Altijd: 3,526
