Ga door naar hoofdinhoud
HP Pavilion dv7-1448dx Battery Replacement
  1. HP Pavilion dv7-1448dx Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure the computer is unplugged and turned off.
    • Place the computer front side down with the battery compartment farthest away.
  2. HP Pavilion dv7-1448dx Battery Replacement: stap 2, afbeelding 1 van 2 HP Pavilion dv7-1448dx Battery Replacement: stap 2, afbeelding 2 van 2
    • Slide the switch under the battery compartment to the left until the compartment opens. This may require some force.
  3. HP Pavilion dv7-1448dx Battery Replacement: stap 3, afbeelding 1 van 2 HP Pavilion dv7-1448dx Battery Replacement: stap 3, afbeelding 2 van 2
    • Lightly pry the battery upward to remove.
    • When reinserting the battery, match the latches along the backside of the battery with the corresponding slots in the computer in order to press it into place.
Conclusie
To reinsert a new battery, follow these instructions in reverse order.
Kirsten Gilliland
741 Reputatie
4 handleidingen geschreven
Baylor, Team 3-5, Whitney Spring 2017 Lid van Baylor, Team 3-5, Whitney Spring 2017
BU-WHITNEY-S17S3G5
2 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 256
