Ga door naar hoofdinhoud
HP Pavilion dv7-1285dx RAM Replacement
Wat je nodig hebt
  1. HP Pavilion dv7-1285dx RAM Replacement, Battery: stap 1, afbeelding 1 van 1
    • Ensure the device is powered down and unplugged.
    • Turn the device upside down with the battery compartment facing you.
    • Slide the black slider to the right and lift the battery out of its compartment.
  2. HP Pavilion dv7-1285dx RAM Replacement, Back Plate: stap 2, afbeelding 1 van 1
    • Locate and remove the six Phillips PM2.5×7.0 screws around the perimeter of the back plate.
    • These screws do not completely detach from the device when unscrewed.
  3. HP Pavilion dv7-1285dx RAM Replacement: stap 3, afbeelding 1 van 2 HP Pavilion dv7-1285dx RAM Replacement: stap 3, afbeelding 2 van 2
    • Use the plastic opening tool to lift up the back plate and set it aside.
  4. HP Pavilion dv7-1285dx RAM Replacement, RAM: stap 4, afbeelding 1 van 1
    • Rotate the device 90 degrees to the left.
  5. HP Pavilion dv7-1285dx RAM Replacement: stap 5, afbeelding 1 van 3 HP Pavilion dv7-1285dx RAM Replacement: stap 5, afbeelding 2 van 3 HP Pavilion dv7-1285dx RAM Replacement: stap 5, afbeelding 3 van 3
    • Locate the grey clips on the side of the RAM and pull the grey clips away from the RAM using the plastic opening tool.
  6. HP Pavilion dv7-1285dx RAM Replacement: stap 6, afbeelding 1 van 3 HP Pavilion dv7-1285dx RAM Replacement: stap 6, afbeelding 2 van 3 HP Pavilion dv7-1285dx RAM Replacement: stap 6, afbeelding 3 van 3
    • Unplug the RAM.
    • Repeat step 6 to remove the second piece of RAM.
  7. HP Pavilion dv7-1285dx RAM Replacement: stap 7, afbeelding 1 van 2 HP Pavilion dv7-1285dx RAM Replacement: stap 7, afbeelding 2 van 2
    • These steps are important in the replacement of the RAM, they will assist in ensuring the device is not damaged.
    • Align the notch in the new RAM with the peg on the plug
    • Ensure the RAM is fully inserted into the plug at a 45 degree angle such that the notch of the RAM lines up with the peg on the plug
  8. HP Pavilion dv7-1285dx RAM Replacement: stap 8, afbeelding 1 van 2 HP Pavilion dv7-1285dx RAM Replacement: stap 8, afbeelding 2 van 2
    • Push down gently on the RAM until the grey clips click.
    • Repeat steps 7 and 8 to replace the second piece of RAM.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jesse Quisido
489 Reputatie
3 handleidingen geschreven
Cal Poly, Team 12-34, Maness Spring 2014 Lid van Cal Poly, Team 12-34, Maness Spring 2014
CPSU-MANESS-S14S12G34
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 6
Altijd: 1,124
