Ga door naar hoofdinhoud
HP Pavilion dv7-1285dx Back Plate Replacement
Wat je nodig hebt
  1. HP Pavilion dv7-1285dx Back Plate Replacement, Battery: stap 1, afbeelding 1 van 1
    • Ensure the device is powered down and unplugged.
    • Turn the device upside down with the battery compartment facing you.
    • Slide the black slider to the right and lift the battery out of its compartment.
  2. HP Pavilion dv7-1285dx Back Plate Replacement, Back Plate: stap 2, afbeelding 1 van 1
    • Locate and remove the six Phillips PM2.5×7.0 screws around the perimeter of the back plate.
    • These screws do not completely detach from the device when unscrewed.
  3. HP Pavilion dv7-1285dx Back Plate Replacement: stap 3, afbeelding 1 van 2 HP Pavilion dv7-1285dx Back Plate Replacement: stap 3, afbeelding 2 van 2
    • Use the plastic opening tool to lift up the back plate and set it aside.
Conclusie
Chris Apple
239 Reputatie
2 handleidingen geschreven
Cal Poly, Team 12-34, Maness Spring 2014 Lid van Cal Poly, Team 12-34, Maness Spring 2014
CPSU-MANESS-S14S12G34
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 1,538
