Ga door naar hoofdinhoud
HP Pavilion dv6700 Motherboard Replacement
Wat je nodig hebt
  1. HP Pavilion dv6700 Motherboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip over the device so that the bottom is facing you.
    • Locate the battery on the bottom of your laptop.
  2. HP Pavilion dv6700 Motherboard Replacement: stap 2, afbeelding 1 van 2 HP Pavilion dv6700 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Slide the tab all the way over to the left until battery pops out. Lift out and remove battery.
  3. HP Pavilion dv6700 Motherboard Replacement, Display/Monitor: stap 3, afbeelding 1 van 2 HP Pavilion dv6700 Motherboard Replacement, Display/Monitor: stap 3, afbeelding 2 van 2
    • Remove the RAM port cover by unscrewing the two screws.
    • These screws can not be fully removed because they’re captive. Loosen them until they turn freely.
  4. HP Pavilion dv6700 Motherboard Replacement: stap 4, afbeelding 1 van 2 HP Pavilion dv6700 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the two screws securing Hard Disk Drive (HDD) cover.
    • Screws will not fully remove. Loosen them until they turn freely.
  5. HP Pavilion dv6700 Motherboard Replacement: stap 5, afbeelding 1 van 3 HP Pavilion dv6700 Motherboard Replacement: stap 5, afbeelding 2 van 3 HP Pavilion dv6700 Motherboard Replacement: stap 5, afbeelding 3 van 3
    • Use a Phillips #00 screwdriver to remove the 25 screws securing the bottom of the computer.
  6. HP Pavilion dv6700 Motherboard Replacement: stap 6, afbeelding 1 van 3 HP Pavilion dv6700 Motherboard Replacement: stap 6, afbeelding 2 van 3 HP Pavilion dv6700 Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Detach WiFi antenna wires.
    • Be sure that the wires are labeled so you remember which ones go where.
  7. HP Pavilion dv6700 Motherboard Replacement: stap 7, afbeelding 1 van 3 HP Pavilion dv6700 Motherboard Replacement: stap 7, afbeelding 2 van 3 HP Pavilion dv6700 Motherboard Replacement: stap 7, afbeelding 3 van 3
    • Using the Phillips #0 screwdriver remove the 2 screws.
    • Use a needle-nose pliers to do the initial loosening, then switch to using a hex screwdriver (size 5) head to do the rest of the loosening.
  8. HP Pavilion dv6700 Motherboard Replacement: stap 8, afbeelding 1 van 2 HP Pavilion dv6700 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Flip over HP Pavilion dv6700 so that the top is facing you.
    • Open up HP Pavilion dv6700.
  9. HP Pavilion dv6700 Motherboard Replacement: stap 9, afbeelding 1 van 3 HP Pavilion dv6700 Motherboard Replacement: stap 9, afbeelding 2 van 3 HP Pavilion dv6700 Motherboard Replacement: stap 9, afbeelding 3 van 3
    • Use an iFixit opening tool to pry open the plastic bar above the keyboard.
    • Be careful not to yank so hard that you rip out the ribbon cables underneath. There is enough room to pull safely, but use control to prevent damage.
  10. HP Pavilion dv6700 Motherboard Replacement: stap 10, afbeelding 1 van 3 HP Pavilion dv6700 Motherboard Replacement: stap 10, afbeelding 2 van 3 HP Pavilion dv6700 Motherboard Replacement: stap 10, afbeelding 3 van 3
    • Pull out and up on keyboard to remove it.
    • Do not yank it all of the way out, as there is a ribbon cable underneath.
    • Slide the two black locks on the side of the keyboard cable connection port up to release the cable.
    • Grip the ribbon cable near the connection point and gently but firmly pull it out.
  11. HP Pavilion dv6700 Motherboard Replacement: stap 11, afbeelding 1 van 2 HP Pavilion dv6700 Motherboard Replacement: stap 11, afbeelding 2 van 2
    • Flip over the plastic bar.
    • Detach the display connector.
    • Do not pull on the wires. Pull on the black plastic part or wedge an iFixit opening tool or fingernail between the port and the connector.
  12. HP Pavilion dv6700 Motherboard Replacement: stap 12, afbeelding 1 van 3 HP Pavilion dv6700 Motherboard Replacement: stap 12, afbeelding 2 van 3 HP Pavilion dv6700 Motherboard Replacement: stap 12, afbeelding 3 van 3
    • Detach the ribbon cables.
    • Pull from the area closest to the connection port gently but firmly.
  13. HP Pavilion dv6700 Motherboard Replacement: stap 13, afbeelding 1 van 3 HP Pavilion dv6700 Motherboard Replacement: stap 13, afbeelding 2 van 3 HP Pavilion dv6700 Motherboard Replacement: stap 13, afbeelding 3 van 3
    • Pull up on tape holding down wires.
  14. HP Pavilion dv6700 Motherboard Replacement: stap 14, afbeelding 1 van 3 HP Pavilion dv6700 Motherboard Replacement: stap 14, afbeelding 2 van 3 HP Pavilion dv6700 Motherboard Replacement: stap 14, afbeelding 3 van 3
    • Pull up on the WiFi wires and out from under the metal tabs.
    • Do not yank them out. Let them hang loose once they are out from under the tabs.
  15. HP Pavilion dv6700 Motherboard Replacement: stap 15, afbeelding 1 van 3 HP Pavilion dv6700 Motherboard Replacement: stap 15, afbeelding 2 van 3 HP Pavilion dv6700 Motherboard Replacement: stap 15, afbeelding 3 van 3
    • Disconnect the connector from the port.
    • Remove the wire from under the metal tabs.
    • Let wire hang loose after removing under the tabs.
  16. HP Pavilion dv6700 Motherboard Replacement: stap 16, afbeelding 1 van 2 HP Pavilion dv6700 Motherboard Replacement: stap 16, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the black screw located in the top right corner near the display.
  17. HP Pavilion dv6700 Motherboard Replacement: stap 17, afbeelding 1 van 2 HP Pavilion dv6700 Motherboard Replacement: stap 17, afbeelding 2 van 2
    • Pull upward on the screen connector tab.
    • It will be firmly secured, so don't be afraid to use a little extra force to pull it off.
  18. HP Pavilion dv6700 Motherboard Replacement: stap 18, afbeelding 1 van 2 HP Pavilion dv6700 Motherboard Replacement: stap 18, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the black screw securing the screen.
    • Keep your hand on the screen to secure it, as once you remove this screw, it will come loose.
    • Lift the screen off and set it aside.
  19. HP Pavilion dv6700 Motherboard Replacement, Motherboard: stap 19, afbeelding 1 van 3 HP Pavilion dv6700 Motherboard Replacement, Motherboard: stap 19, afbeelding 2 van 3 HP Pavilion dv6700 Motherboard Replacement, Motherboard: stap 19, afbeelding 3 van 3
    • Unscrew the black screw in the top right corner using the Phillips #00 screwdriver.
    • Pull up on the top piece and remove it.
  20. HP Pavilion dv6700 Motherboard Replacement: stap 20, afbeelding 1 van 3 HP Pavilion dv6700 Motherboard Replacement: stap 20, afbeelding 2 van 3 HP Pavilion dv6700 Motherboard Replacement: stap 20, afbeelding 3 van 3
    • Remove the screw in top left corner using the Phillips #00 screwdriver
    • Remove the five screws that are located on the motherboard cover.
    • Pull up on the cover to remove it.
    • You can use a plastic opener if it is hard to get your fingers under the cover's edges.
    • Do not pull hard on the cover, as there are two ribbon cables under the cover connected to the motherboard.
  21. HP Pavilion dv6700 Motherboard Replacement: stap 21, afbeelding 1 van 3 HP Pavilion dv6700 Motherboard Replacement: stap 21, afbeelding 2 van 3 HP Pavilion dv6700 Motherboard Replacement: stap 21, afbeelding 3 van 3
    • Pull gently but firmly on the ribbon cables at the connection points to remove them
  22. HP Pavilion dv6700 Motherboard Replacement: stap 22, afbeelding 1 van 3 HP Pavilion dv6700 Motherboard Replacement: stap 22, afbeelding 2 van 3 HP Pavilion dv6700 Motherboard Replacement: stap 22, afbeelding 3 van 3
    • Remove the four screws from the ExpressCard component using the Phillips #00 screwdriver.
  23. HP Pavilion dv6700 Motherboard Replacement: stap 23, afbeelding 1 van 3 HP Pavilion dv6700 Motherboard Replacement: stap 23, afbeelding 2 van 3 HP Pavilion dv6700 Motherboard Replacement: stap 23, afbeelding 3 van 3
    • Remove ExpressCard component by sliding it out.
    • Remove Optical Drive by sliding it out.
  24. HP Pavilion dv6700 Motherboard Replacement: stap 24, afbeelding 1 van 2 HP Pavilion dv6700 Motherboard Replacement: stap 24, afbeelding 2 van 2
    • Detach connector from the motherboard.
    • This piece is likely to be very hard to disconnect, so do not be afraid to use more force than normal.
  25. HP Pavilion dv6700 Motherboard Replacement: stap 25, afbeelding 1 van 1
    • Using the Phillips #00 screwdriver, remove the one screw near where the ExpressCard component was.
  26. HP Pavilion dv6700 Motherboard Replacement: stap 26, afbeelding 1 van 3 HP Pavilion dv6700 Motherboard Replacement: stap 26, afbeelding 2 van 3 HP Pavilion dv6700 Motherboard Replacement: stap 26, afbeelding 3 van 3
    • Lift up motherboard.
    • Detach the motherboard connector at the front under the motherboard.
  27. HP Pavilion dv6700 Motherboard Replacement: stap 27, afbeelding 1 van 3 HP Pavilion dv6700 Motherboard Replacement: stap 27, afbeelding 2 van 3 HP Pavilion dv6700 Motherboard Replacement: stap 27, afbeelding 3 van 3
    • Lift up and out the motherboard.
    • Detach the connector under the motherboard.
    • Remove the motherboard.
    come si fà a pulire o stappare le canaline in rame di raffreddamento del processore?
    Giorgio D'Ulizia - Antwoord
    To clean, use cotton or cotton swabs with isopropyl alcohol. Be sure to let it fully dry before putting back together.
    Google translate English to Italian: Per pulire, utilizzare cotton o cotton fioc con alcol isopropilico. Assicurati di lasciarlo asciugare completamente prima di rimontarlo.
    Alec Gramm -
    Sir mother board of a dv 6000 and dv 6700 the same?
    Fernando - Antwoord
    I do not believe that they are.
    Alec Gramm -
Conclusie
8 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Brilliant presentation.
Great Help
Thanks
ivor - Antwoord
Thank you for all your help . Very decent of you.
Spot on guide and detail.
Ian, Poynton< Cheshire
UK.
558vulcanxh - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 27
Altijd: 3,400
