Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
Be sure to wear the anti-static guard strap, as you will be coming into contact with circuitry, and static electricity would permanently damage it.
Wat je nodig hebt
Flip over the device so that the bottom is facing you.
Locate the battery on the bottom of your laptop.
Unscrew the black screw in the top right corner using the Phillips #00 screwdriver.
Pull up on the top piece and remove it.
4 andere personen hebben deze handleiding voltooid.
