Wat je nodig hebt
Make sure the laptop lid is closed, turn it over and remove the battery by moving the switch right to left.
there are three philips screws located on the surface where the writing is. remove those three screws.
turn the laptop right side up. Between the cover and case on the top right of the laptop and using a plastic sludger or a finger lift gently on the speaker cover as to disengage the clips.
Be sure not to pull hard or you may damage the ribbon cables.
From the side closest to the screen turn the cover towards yourself.
5 andere personen hebben deze handleiding voltooid.
2 opmerkingen
how to fix speaker from board
Grazie siete bravissimi . Ce ne fossero persone come voi che altruisticamente mettono a disposizione la loro esperienza di riparazioni per gli altri!
Fernando Mancini
