Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the following screws:
There are five(5) 5.8 mm Phillips screws located in the battery compartment, where the battery formerly resided.
There are fifteen(15) 7.2 mm Phillips screws that secure the lower case to the upper case of the laptop.
Loosen the two captive screws on the right hand side of the hard drive cover. The screws will remain attached to the cover.
Remove the hard drive by lifting it up vertically on the right hand side. There is usually a plastic pull tab to help. If this does not work, gently pry it out with a flat head screwdriver.
Remove the one screw under the hard drive. This will help release the motherboard for later steps.
Remove the screw above the RAM access cover that holds the CD drive in place. Then, slide the drive to the left out of the case. Be careful not to pull the front off of the tray itself.
Remove the three(3) screws along the edge that are revealed after removing the CD drive. These screws hold the top bezel to the bottom frame.
After taking out the three(3) screws, flip the laptop over so that the keyboard side is up.
Remove the center cable from its connector on the button panel. Then, gently release the friction locks that secure the left and right ribbon cables by pushing them away from their connectors. The ribbon cables will slip out of their connectors.
After completing step 4, flip the laptop over again, making sure the battery side is up. Remove the two screws securing the RAM shield to the lower case.
Lift and remove the RAM shield up from the lower case; The screws will remain captive within the shield.
Remove the black Philips screw marked with a Keyboard icon.
After finishing step 5, turn the computer over and gently lift the keyboard at the top corners, sliding it upward and towards the screen. The bottom tabs will slide out from below the palm rest and the keyboard may be turned over to reveal the connection cable.
Disconnect the keyboard ribbon cable (highlighted in red) from its socket on the motherboard.
Remove the four 5.8 mm Phillips screws securing the top cover to the lower case.
Gereedschap gebruikt in deze stap:Tweezers$4.99-
Use a pair of tweezers to disconnect both antennas from their sockets on the wireless card. These are snap-on connectors, so simply pull them straight up to snap them off the studs on the card.
Remove the two(2) 3.7 mm Phillips screws securing the wireless card to the motherboard.
Grasp the wireless card and pull it straight out of its socket on the motherboard.
The LCD needs to be removed to proceed. Start by disconnecting the marked cable from its socket and disconnecting the cables from their clips in the palm rest.
Proceed to pull the two WiFi antenna cables through the motherboard.
Remove the screws that hold each LCD hinge cover in place. There is 1 screw for each cover.
Gently pry each cover off its hinge.
Remove the Video cable by grabbing the ribbon and lifting up.
Lift up the LCD and its three cable bundles and set it aside.
Use a pair of tweezers (or 3/16 nut driver) to remove the two 5mm hex screws secured to the logic board.
Remove the screw on the far top right hand side. Then carefully pry the bezel free.
Pull the final cable connections from their sockets on the motherboard. Undo the top-left screw, then gently lift the palm rest towards you starting back to front(in orange).
Remove the two(2) 3.8 mm Phillips screws securing the left edge of the expansion port board to the motherboard.
Remove the two 3.8 mm Phillips screws securing the right edge of the expansion port board to the motherboard.
Lift and remove the expansion port board out of the lower case.
Remove the final screw holding the motherboard in place. Then gently lift the motherboard up vertically.
Remove the two marked cables. These will be tight. Do not pull by the wires. Carefully wiggle the connectors only.
Remove the final data cable near the front of the system board. The motherboard will be free. Lift up and towards the left to remove from the base.
Lift and remove the motherboard from the lower case.
To remove the heat sink,remove the marked screws and remove the fan's power cable. Clean the CPU/heat sink and add new thermal paste.
41 andere personen hebben deze handleiding voltooid.
7 opmerkingen
i need a dv 6000 pavilon motherboard. what is the cost. reach me on obiomaokerej@gmail.com
New is about $300 depending on your specific model. You can find used ones at around $75-150 on ebay. I'd be happy to help you locate parts if you give me the exact model number
Goodday! When I turn on my dv6, the power button just blink light and the laptop go off. Pls what can I do
Hi, i need a new mother board form this model. Spar part number: 578378-001. Are you be able to tell me where I can buy it at lower price? I live in Italy.
