Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the two screws from the hard drive shield and lift it off starting at the right side. The screws will remain in the shield.
Pull the plastic tab attached to the hard drive. The hard drive lifts right out. Pull gently so you don't damage the contacts.
Gently pull forward the HP adapter from the top of the hard drive.
Insert the adapter onto the new SATA hard drive, to be replaced in the laptop.
19 andere personen hebben deze handleiding voltooid.
2 opmerkingen
I was scratching my head when I recvd the new hd w/out the adapter... LOL! thanks
