Ga door naar hoofdinhoud
HP Pavilion dv6000 Hard Drive Replacement
Wat je nodig hebt
  1. HP Pavilion dv6000 Hard Drive Replacement, Hard Drive: stap 1, afbeelding 1 van 2 HP Pavilion dv6000 Hard Drive Replacement, Hard Drive: stap 1, afbeelding 2 van 2
    • Remove the two screws from the hard drive shield and lift it off starting at the right side. The screws will remain in the shield.
    this was very unexpected place to find the answer to my dilemma being unable to figure this hp silliness out; for a couple of months i sat on the upgrade of this almost unusable laptop. i was going to just list it as mostly junk on ebay. all it was is a stupid hp ssd adapter!? i kept looking for an adapter to go the other way unaware it was already there that is why it did not make sense! im trying not to scream! anyway thanks to this wonderful site my laptop is now much more ready to sell as vintage. all it took was a simple photo and sentence "remove the adapter from the hdd"!
    D C Gubler - Antwoord
  2. HP Pavilion dv6000 Hard Drive Replacement: stap 2, afbeelding 1 van 2 HP Pavilion dv6000 Hard Drive Replacement: stap 2, afbeelding 2 van 2
    • Pull the plastic tab attached to the hard drive. The hard drive lifts right out. Pull gently so you don't damage the contacts.
  3. HP Pavilion dv6000 Hard Drive Replacement: stap 3, afbeelding 1 van 2 HP Pavilion dv6000 Hard Drive Replacement: stap 3, afbeelding 2 van 2
    • Now you have your hard drive out!
  4. HP Pavilion dv6000 Hard Drive Replacement: stap 4, afbeelding 1 van 2 HP Pavilion dv6000 Hard Drive Replacement: stap 4, afbeelding 2 van 2
    • Gently pull forward the HP adapter from the top of the hard drive.
    • Insert the adapter onto the new SATA hard drive, to be replaced in the laptop.
Conclusie
19 andere personen hebben deze handleiding voltooid.
Ben Hirsch
3.826 Reputatie
10 handleidingen geschreven
Cal Poly, Team 21-33, Regan Fall 2010 Lid van Cal Poly, Team 21-33, Regan Fall 2010
CPSU-REGAN-F10S21G33
4 Leden
12 handleidingen geschreven
2 opmerkingen
thanks for your help
moyguens - Antwoord
I was scratching my head when I recvd the new hd w/out the adapter... LOL! thanks
gilaraujog - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 39
Altijd: 41,201
