Ga door naar hoofdinhoud
HP Pavilion dv6-6180us Screen Replacement
Wat je nodig hebt
  1. HP Pavilion dv6-6180us Screen Replacement, Hard Drive: stap 1, afbeelding 1 van 1
    • Turn off and unplug the device before starting.
    • Flip your device over so the bottom panel is facing up.
    Vraag FixBot
  2. HP Pavilion dv6-6180us Screen Replacement: stap 2, afbeelding 1 van 1
    • Slide the lock switch to the right.
    • The panel will pop open at the top corner.
    Vraag FixBot
  3. HP Pavilion dv6-6180us Screen Replacement: stap 3, afbeelding 1 van 1
    • Use the plastic opening tool to remove the back panel.
    • Some force may be required to remove the panel from the case. Use caution when prying to avoid breaking the panel or the plastic tabs securing it in place.
    Vraag FixBot
  4. HP Pavilion dv6-6180us Screen Replacement: stap 4, afbeelding 1 van 1
    • Use the PH 1 screwdriver to remove the four 3.5 mm screws securing the hard drive.
    Vraag FixBot
  5. HP Pavilion dv6-6180us Screen Replacement: stap 5, afbeelding 1 van 1
    • Lift the corner bracket to remove the hard drive.
    Vraag FixBot
  6. HP Pavilion dv6-6180us Screen Replacement: stap 6, afbeelding 1 van 1
    • Unplug the hard drive wire to detach the hard drive.
    Vraag FixBot
  7. HP Pavilion dv6-6180us Screen Replacement, Screen: stap 7, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Using tweezers, grab the top and bottom while rocking back and forth to pull rubber plug out.
    • Cover is glued into place so gently pick at the edge before removing.
    Vraag FixBot
  8. HP Pavilion dv6-6180us Screen Replacement: stap 8, afbeelding 1 van 1
    • Unscrew two 6mm screws using PH1 screwdriver.
    Vraag FixBot
  9. HP Pavilion dv6-6180us Screen Replacement: stap 9, afbeelding 1 van 1
    • Pry the left lower corner with fingers.
    Vraag FixBot
  10. HP Pavilion dv6-6180us Screen Replacement: stap 10, afbeelding 1 van 1
    • Remove screen frame.
    Vraag FixBot
  11. HP Pavilion dv6-6180us Screen Replacement: stap 11, afbeelding 1 van 2 HP Pavilion dv6-6180us Screen Replacement: stap 11, afbeelding 2 van 2
    • Unscrew two 3mm screws using PH 1 screwdriver
    • Eight 6mm screws using PH 1 screwdriver.
    • Use PH 000 screwdriver to remove two 4mm screws.
    Vraag FixBot
  12. HP Pavilion dv6-6180us Screen Replacement: stap 12, afbeelding 1 van 1
    • Pry open the keyboard using plastic opening tool starting from the top.
    • Lift up keyboard gently because a silver ribbon is still attaching it to the laptop.
    Vraag FixBot
  13. HP Pavilion dv6-6180us Screen Replacement: stap 13, afbeelding 1 van 3 HP Pavilion dv6-6180us Screen Replacement: stap 13, afbeelding 2 van 3 HP Pavilion dv6-6180us Screen Replacement: stap 13, afbeelding 3 van 3
    • Place keyboard upside down.
    • Lift up plastic cover over keyboard connector cable.
    • Pull ribbon cable up away from keyboard to completely remove.
    Vraag FixBot
  14. HP Pavilion dv6-6180us Screen Replacement: stap 14, afbeelding 1 van 1
    • Remove seven 4mm pannel screws with PH 1 screwdriver.
    Vraag FixBot
  15. HP Pavilion dv6-6180us Screen Replacement: stap 15, afbeelding 1 van 1
    • Place the computer on its side.
    • Separate top panel from bottom frame.
    Vraag FixBot
  16. HP Pavilion dv6-6180us Screen Replacement: stap 16, afbeelding 1 van 2 HP Pavilion dv6-6180us Screen Replacement: stap 16, afbeelding 2 van 2
    • Pop open rest palm assembly.
    Vraag FixBot
  17. HP Pavilion dv6-6180us Screen Replacement: stap 17, afbeelding 1 van 1
    • Pull ribbon to detach from bottom panel.
    Vraag FixBot
  18. HP Pavilion dv6-6180us Screen Replacement: stap 18, afbeelding 1 van 1
    • Remove two 5mm screws securing fan, using HP 1 screwdriver.
    Vraag FixBot
  19. HP Pavilion dv6-6180us Screen Replacement: stap 19, afbeelding 1 van 1
    • Flip laptop over.
    • Remove two 4mm screws securing antenna using PH 1 screwdriver.
    • Pull antenna to the right to remove.
    Vraag FixBot
  20. HP Pavilion dv6-6180us Screen Replacement: stap 20, afbeelding 1 van 1
    • Flip laptop side up.
    • Pull off yellow insulating tape.
    Vraag FixBot
  21. HP Pavilion dv6-6180us Screen Replacement: stap 21, afbeelding 1 van 2 HP Pavilion dv6-6180us Screen Replacement: stap 21, afbeelding 2 van 2
    • Grab tab on left top corner and remove black wire.
    • Remove white input attachment.
    Vraag FixBot
  22. HP Pavilion dv6-6180us Screen Replacement: stap 22, afbeelding 1 van 1
    • Lift up speaker.
    Vraag FixBot
  23. HP Pavilion dv6-6180us Screen Replacement: stap 23, afbeelding 1 van 1
    • Hold the motherboard and pull to the right.
    • The plugs on the left may be difficult to snap out.
    Vraag FixBot
  24. HP Pavilion dv6-6180us Screen Replacement: stap 24, afbeelding 1 van 1
    • Remove a 4mm screw securing wire attachment using PH 1 screwdriver.
    Vraag FixBot
  25. HP Pavilion dv6-6180us Screen Replacement: stap 25, afbeelding 1 van 1
    • Remove two hinge covers.
    Vraag FixBot
  26. HP Pavilion dv6-6180us Screen Replacement: stap 26, afbeelding 1 van 1
    • Unhook the antenna wire from behind hinge.
    Vraag FixBot
  27. HP Pavilion dv6-6180us Screen Replacement: stap 27, afbeelding 1 van 1
    • Lay screen face down.
    • Detach silver wire from screen
    Vraag FixBot
Conclusie
Één andere persoon heeft deze handleiding voltooid.
michelle pulido
859 Reputatie
4 handleidingen geschreven
CSU Fullerton, Team 1-2, Bruce Fall 2016 Lid van CSU Fullerton, Team 1-2, Bruce Fall 2016
CSUF-BRUCE-F16S1G2
4 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 45
Altijd: 2,066
