Ga door naar hoofdinhoud
HP Pavilion dv6-6117dx WiFi Adapter Replacement
Wat je nodig hebt
  1. HP Pavilion dv6-6117dx WiFi Adapter Replacement, WiFi Card: stap 1, afbeelding 1 van 2 HP Pavilion dv6-6117dx WiFi Adapter Replacement, WiFi Card: stap 1, afbeelding 2 van 2
    • Begin removing the bottom cover by sliding the battery removal slider to the right to pop off the top of the cover.
  2. HP Pavilion dv6-6117dx WiFi Adapter Replacement: stap 2, afbeelding 1 van 2 HP Pavilion dv6-6117dx WiFi Adapter Replacement: stap 2, afbeelding 2 van 2
    • Slide a black spudger under the top of the cover to loosen the clips underneath.
  3. HP Pavilion dv6-6117dx WiFi Adapter Replacement: stap 3, afbeelding 1 van 3 HP Pavilion dv6-6117dx WiFi Adapter Replacement: stap 3, afbeelding 2 van 3 HP Pavilion dv6-6117dx WiFi Adapter Replacement: stap 3, afbeelding 3 van 3
    • Slide the spudger down the left side of the cover to loosen the clips.
    • After the left side is loose, the rest of the cover should pop off, and you can remove it with your hands.
    • When reassembling, insert the bottom of the cover first, and then firmly press along the edges from bottom to top to secure it in place.
  4. HP Pavilion dv6-6117dx WiFi Adapter Replacement: stap 4, afbeelding 1 van 3 HP Pavilion dv6-6117dx WiFi Adapter Replacement: stap 4, afbeelding 2 van 3 HP Pavilion dv6-6117dx WiFi Adapter Replacement: stap 4, afbeelding 3 van 3
    • Using a spudger, remove the white and black antenna wires from the WiFi Adapter
    • When connecting these wires later, line up the connector and press straight down until you feel them snap in place.
  5. HP Pavilion dv6-6117dx WiFi Adapter Replacement: stap 5, afbeelding 1 van 3 HP Pavilion dv6-6117dx WiFi Adapter Replacement: stap 5, afbeelding 2 van 3 HP Pavilion dv6-6117dx WiFi Adapter Replacement: stap 5, afbeelding 3 van 3
    • Using a Phillips #0 screw driver, remove the two 4mm screws holding the WiFi adapter in place
    • After the screws are removed the WiFi Adapter will raise to a 45º angle.
  6. HP Pavilion dv6-6117dx WiFi Adapter Replacement: stap 6, afbeelding 1 van 2 HP Pavilion dv6-6117dx WiFi Adapter Replacement: stap 6, afbeelding 2 van 2
    • Always handle the WiFi Adapter by the edges to avoid damaging the part.
    • Pull the WiFi Adapter out of the slot at a 45º angle.
    • When inserting the new WiFi Adapter, you should insert it at this same angle.
Conclusie
Joshua Holme
765 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team S6-G3, Bernier Spring 2018 Lid van UMass Dartmouth, Team S6-G3, Bernier Spring 2018
UMASSD-BERNIER-S18S6G3
3 Leden
Één opmerking
Thanks i need to replace the wifi adapter in an old pc of mine,looks pretty simple.
pturner14 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 41
Altijd: 2,351
