Ga door naar hoofdinhoud
HP Pavilion dv6-6117dx RAM Replacement
Wat je nodig hebt
  1. HP Pavilion dv6-6117dx RAM Replacement, RAM: stap 1, afbeelding 1 van 2 HP Pavilion dv6-6117dx RAM Replacement, RAM: stap 1, afbeelding 2 van 2
    • Begin removing the bottom cover by sliding the battery removal slider to the right to pop off the top of the cover.
  2. HP Pavilion dv6-6117dx RAM Replacement: stap 2, afbeelding 1 van 2 HP Pavilion dv6-6117dx RAM Replacement: stap 2, afbeelding 2 van 2
    • Slide a black spudger under the top of the cover to loosen the clips underneath.
  3. HP Pavilion dv6-6117dx RAM Replacement: stap 3, afbeelding 1 van 3 HP Pavilion dv6-6117dx RAM Replacement: stap 3, afbeelding 2 van 3 HP Pavilion dv6-6117dx RAM Replacement: stap 3, afbeelding 3 van 3
    • Slide the spudger down the left side of the cover to loosen the clips.
    • After the left side is loose, the rest of the cover should pop off, and you can remove it with your hands.
    • When reassembling, insert the bottom of the cover first, and then firmly press along the edges from bottom to top to secure it in place.
  4. HP Pavilion dv6-6117dx RAM Replacement: stap 4, afbeelding 1 van 2 HP Pavilion dv6-6117dx RAM Replacement: stap 4, afbeelding 2 van 2
    • Push the tabs on both sides away from each other to free the RAM, which will raise to a 45º angle.
  5. HP Pavilion dv6-6117dx RAM Replacement: stap 5, afbeelding 1 van 2 HP Pavilion dv6-6117dx RAM Replacement: stap 5, afbeelding 2 van 2
    • Always handle RAM by the edges to avoid damaging the part.
    • Remove the RAM by grabbing it by the sides and pulling out at a 45º angle.
    • When inserting the new stick of RAM, you should insert it at this same angle.
Conclusie
Joshua Holme
765 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team S6-G3, Bernier Spring 2018 Lid van UMass Dartmouth, Team S6-G3, Bernier Spring 2018
UMASSD-BERNIER-S18S6G3
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 22
Altijd: 737
