Ga door naar hoofdinhoud
HP Pavilion dv6-6117dx Hard Drive Replacement
Wat je nodig hebt
  1. HP Pavilion dv6-6117dx Hard Drive Replacement, Hard Drive: stap 1, afbeelding 1 van 2 HP Pavilion dv6-6117dx Hard Drive Replacement, Hard Drive: stap 1, afbeelding 2 van 2
    • Begin removing the bottom cover by sliding the battery removal slider to the right to pop off the top of the cover.
  2. HP Pavilion dv6-6117dx Hard Drive Replacement: stap 2, afbeelding 1 van 2 HP Pavilion dv6-6117dx Hard Drive Replacement: stap 2, afbeelding 2 van 2
    • Slide a black spudger under the top of the cover to loosen the clips underneath.
  3. HP Pavilion dv6-6117dx Hard Drive Replacement: stap 3, afbeelding 1 van 3 HP Pavilion dv6-6117dx Hard Drive Replacement: stap 3, afbeelding 2 van 3 HP Pavilion dv6-6117dx Hard Drive Replacement: stap 3, afbeelding 3 van 3
    • Slide the spudger down the left side of the cover to loosen the clips.
    • After the left side is loose, the rest of the cover should pop off, and you can remove it with your hands.
    • When reassembling, insert the bottom of the cover first, and then firmly press along the edges from bottom to top to secure it in place.
  4. HP Pavilion dv6-6117dx Hard Drive Replacement: stap 4, afbeelding 1 van 3 HP Pavilion dv6-6117dx Hard Drive Replacement: stap 4, afbeelding 2 van 3 HP Pavilion dv6-6117dx Hard Drive Replacement: stap 4, afbeelding 3 van 3
    • Using a Phillips #0 screw driver, remove the four 4mm screws holding the hard drive in place.
  5. HP Pavilion dv6-6117dx Hard Drive Replacement: stap 5, afbeelding 1 van 3 HP Pavilion dv6-6117dx Hard Drive Replacement: stap 5, afbeelding 2 van 3 HP Pavilion dv6-6117dx Hard Drive Replacement: stap 5, afbeelding 3 van 3
    • Using a plastic spudger, lift up the hard drive from the top left corner and flip it to the right of the laptop like opening a book.
    • There is a cable connecting the hard drive to the laptop, be sure not to pull it out when flipping the hard drive.
  6. HP Pavilion dv6-6117dx Hard Drive Replacement: stap 6, afbeelding 1 van 2 HP Pavilion dv6-6117dx Hard Drive Replacement: stap 6, afbeelding 2 van 2
    • Pull the tab at the end of the cable connecting the hard drive to the laptop.
  7. HP Pavilion dv6-6117dx Hard Drive Replacement: stap 7, afbeelding 1 van 3 HP Pavilion dv6-6117dx Hard Drive Replacement: stap 7, afbeelding 2 van 3 HP Pavilion dv6-6117dx Hard Drive Replacement: stap 7, afbeelding 3 van 3
    • Using a Phillips #0 screw driver, remove the four 4mm screws on each side of the hard drive attaching it to its carriage.
  8. HP Pavilion dv6-6117dx Hard Drive Replacement: stap 8, afbeelding 1 van 2 HP Pavilion dv6-6117dx Hard Drive Replacement: stap 8, afbeelding 2 van 2
    • Remove the hard drive from its carriage.
  9. HP Pavilion dv6-6117dx Hard Drive Replacement: stap 9, afbeelding 1 van 2 HP Pavilion dv6-6117dx Hard Drive Replacement: stap 9, afbeelding 2 van 2
    • Remove the SATA cable from the hard drive.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Joshua Holme
765 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team S6-G3, Bernier Spring 2018 Lid van UMass Dartmouth, Team S6-G3, Bernier Spring 2018
UMASSD-BERNIER-S18S6G3
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 44
Altijd: 2,536
