Ga door naar hoofdinhoud
HP Pavilion dv6-2155dx Hard Drive Replacement
Wat je nodig hebt
  1. HP Pavilion dv6-2155dx Hard Drive Replacement, Hard Drive: stap 1, afbeelding 1 van 2 HP Pavilion dv6-2155dx Hard Drive Replacement, Hard Drive: stap 1, afbeelding 2 van 2
    • Shutdown your computer and remove the battery before beginning the replacement.
    • Loosen the screws using Phillips #01 screwdriver with the extension attached.
    • The screws will not come out completely but stay on the panel.
  2. HP Pavilion dv6-2155dx Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • After removing the two screws securing the Hard Drive to the bottom case, remove the panel to reveal the hard drive.
  3. HP Pavilion dv6-2155dx Hard Drive Replacement: stap 3, afbeelding 1 van 2 HP Pavilion dv6-2155dx Hard Drive Replacement: stap 3, afbeelding 2 van 2
    • Locate the tab of the black Mylar film on the right hand side of the hard drive.
    • Gently grip it with your thumb and index finger.
  4. HP Pavilion dv6-2155dx Hard Drive Replacement: stap 4, afbeelding 1 van 2 HP Pavilion dv6-2155dx Hard Drive Replacement: stap 4, afbeelding 2 van 2
    • Pull the Hard Drive to the right to loosen the it from the frame.
    • The left side of the hard drive will pop up and should slide out freely until you see the black connector on it's right side, connecting it to the computer.
  5. HP Pavilion dv6-2155dx Hard Drive Replacement: stap 5, afbeelding 1 van 2 HP Pavilion dv6-2155dx Hard Drive Replacement: stap 5, afbeelding 2 van 2
    • When removing the Hard Drive from the frame, you will see a black connector on it's right side.
    • Turn the Hard Drive over and grasp the Hard Drive with one hand as you grip the connector with the other hand to remove the connector from the hard drive.
    • To safely remove the Hard Driver, do not wiggle or jerk the connector off of the Hard Drive, pull straight off.
Conclusie
Lisa Redder
318 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 2-2, Isaacson Fall 2016 Lid van UMass Dartmouth, Team 2-2, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G2
3 Leden
5 handleidingen geschreven
Één opmerking
Can I transfer the information on the hard drive to another computer? How? My laptop won’t turn on and I’ve tried everything.
Sheree Norton - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 10
Altijd: 1,830
