Ga door naar hoofdinhoud
HP Pavilion dv6-1245dx RAM Replacement
Wat je nodig hebt
  1. HP Pavilion dv6-1245dx RAM Replacement, RAM: stap 1, afbeelding 1 van 1
    • Shut down the computer and unplug it from the outlet.
    • All screws removed in this guide will require a Phillips #00 screwdriver.
  2. HP Pavilion dv6-1245dx RAM Replacement: stap 2, afbeelding 1 van 1
    • Turn the computer upside down.
  3. HP Pavilion dv6-1245dx RAM Replacement: stap 3, afbeelding 1 van 1
    • Loosen the three screws from the memory module compartment cover
    • Screws will not come all the way out.
  4. HP Pavilion dv6-1245dx RAM Replacement: stap 4, afbeelding 1 van 1
    • Remove the memory module compartment cover.
  5. HP Pavilion dv6-1245dx RAM Replacement: stap 5, afbeelding 1 van 3 HP Pavilion dv6-1245dx RAM Replacement: stap 5, afbeelding 2 van 3 HP Pavilion dv6-1245dx RAM Replacement: stap 5, afbeelding 3 van 3
    • Remove the first memory module by spreading apart the two silver retaining tabs, using your thumb and index finger.
    • Pull and lift the green memory module upward at a 45-degree angle, and then pull the memory module out of the computer.
    • If you are replacing both memory cards, repeat this step with the bottom memory card.
  6. HP Pavilion dv6-1245dx RAM Replacement: stap 6, afbeelding 1 van 1
    • To replace the memory card, insert the card at a 45-degree angle, then push into slot.
    • Push down gently so the silver retaining tabs click back into place.
    • If you are replacing both memory cards, replace the bottom card (closest to the system board) first.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Jaime
562 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 18
Altijd: 2,375
