Inleiding
The battery of the HP Pavilion is made to last for only a period of time, after which the battery tends to run low sooner than usual. This means the battery capacity has lessened and may need a replacement. This guide will walk you through the process of accessing the RTC Battery of an HP Pavilion dv5000 in order to replace it.
Wat je nodig hebt
Lay the computer face-down on a flat surface. Orient the computer to match the image.
Locate the battery release switch, as indicated in the image by the red rectangle. Slide the switch from right to left, and remove the battery.
Remove the two 5mm Phillips screws on the right side of the RAM cover.
Lift the right side of the RAM cover, and remove it.
Disconnect the antenna leads from the wifi card by lifting the gold ends of the wires off the prongs on the wifi card.
The white wire connects to the AUX terminal.
The black wire connects to the MAIN terminal.
4 andere personen hebben deze handleiding voltooid.
