Ga door naar hoofdinhoud
HP Pavilion dv5000 RTC Battery Replacement
Wat je nodig hebt
  1. HP Pavilion dv5000 RTC Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn off the computer, and unplug it from all external power sources.
    • Lay the computer face-down on a flat surface. Orient the computer to match the image.
    • Locate the battery release switch, as indicated in the image by the red rectangle. Slide the switch from right to left, and remove the battery.
  2. HP Pavilion dv5000 RTC Battery Replacement, RAM Cover: stap 2, afbeelding 1 van 3 HP Pavilion dv5000 RTC Battery Replacement, RAM Cover: stap 2, afbeelding 2 van 3 HP Pavilion dv5000 RTC Battery Replacement, RAM Cover: stap 2, afbeelding 3 van 3
    • Remove the two 5mm Phillips screws on the right side of the RAM cover.
    • Lift the right side of the RAM cover, and remove it.
  3. HP Pavilion dv5000 RTC Battery Replacement, Wifi Card: stap 3, afbeelding 1 van 2 HP Pavilion dv5000 RTC Battery Replacement, Wifi Card: stap 3, afbeelding 2 van 2
    • Disconnect the antenna leads from the wifi card by lifting the gold ends of the wires off the prongs on the wifi card.
    • The white wire connects to the AUX terminal.
    • The black wire connects to the MAIN terminal.
  4. HP Pavilion dv5000 RTC Battery Replacement: stap 4, afbeelding 1 van 2 HP Pavilion dv5000 RTC Battery Replacement: stap 4, afbeelding 2 van 2
    • Remove the two 6.0mm Phillips screws from the wifi card.
    • Remove the wifi card.
  5. HP Pavilion dv5000 RTC Battery Replacement, RTC Battery: stap 5, afbeelding 1 van 3 HP Pavilion dv5000 RTC Battery Replacement, RTC Battery: stap 5, afbeelding 2 van 3 HP Pavilion dv5000 RTC Battery Replacement, RTC Battery: stap 5, afbeelding 3 van 3
    • Remove the RTC Battery from the battery holder.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Farid Khoshnevissan
820 Reputatie
4 handleidingen geschreven
Cal Poly, Team 21-34, Regan Fall 2010 Lid van Cal Poly, Team 21-34, Regan Fall 2010
CPSU-REGAN-F10S21G34
4 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 14
Altijd: 11,911
