Ga door naar hoofdinhoud
HP Pavilion dv5000 Keyboard Replacement
Wat je nodig hebt
  1. HP Pavilion dv5000 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn off the computer, and unplug it from all external power sources.
    • Lay the computer face-down on a flat surface. Orient the computer to match the image.
    • Locate the battery release switch, as indicated in the image by the red rectangle. Slide the switch from right to left, and remove the battery.
  2. HP Pavilion dv5000 Keyboard Replacement, Keyboard: stap 2, afbeelding 1 van 1
    • Remove the two 11.0mm screws at the corners on either side of the battery compartment.
    • Remove the three 6.0mm screws.
    • Remove the two 5.0mm screws.
    • Remove the 6.0mm screw in the middle of the battery compartment.
  3. HP Pavilion dv5000 Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Turn the computer over and open the screen. This provides access to the screen hinges.
    • The keyboard switch cover is attached to the computer with a series of snaps. With a flathead screwdriver, pry up the switch cover until it pops free.
  4. HP Pavilion dv5000 Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Be careful not to bend the keyboard switch cover too far when removing it.
  5. HP Pavilion dv5000 Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Next, remove the keyboard. Push on the keyboard frame above the function keys and slide the keyboard toward the screen.
  6. HP Pavilion dv5000 Keyboard Replacement: stap 6, afbeelding 1 van 2 HP Pavilion dv5000 Keyboard Replacement: stap 6, afbeelding 2 van 2
    • Carefully lift the trackpad-side edge of the keyboard to reveal the LED and keyboard cable connectors.
    • Detach the cable connectors from the computer by gripping each cable connector close to the computer contact point and pulling up gently.
  7. HP Pavilion dv5000 Keyboard Replacement: stap 7, afbeelding 1 van 1
    • This step is for replacing the keyboard only. If you are not replacing the keyboard, skip this step.
    • Lay the keyboard face down.
    • Remove the four 3.00mm screws that attach the keyboard to the keyboard frame.
  8. HP Pavilion dv5000 Keyboard Replacement: stap 8, afbeelding 1 van 1
    • Lift the keyboard off the keyboard frame.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Alex Kwok
271 Reputatie
3 handleidingen geschreven
Cal Poly, Team 21-34, Regan Fall 2010 Lid van Cal Poly, Team 21-34, Regan Fall 2010
CPSU-REGAN-F10S21G34
4 Leden
11 handleidingen geschreven
2 opmerkingen
Hey is keyboard replacement same or very similiar procedure with hp dv8000?
Arkadiusz Gąsior - Antwoord
Brilliant. This is the best tutorial out there. Many thanks indeed!!!!
stevefranklin75 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 11,218
