Ga door naar hoofdinhoud
Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
HP Pavilion dv5000 Hard Drive Replacement
Wat je nodig hebt
  1. HP Pavilion dv5000 Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn off the computer, and unplug it from all external power sources.
    • Lay the computer face-down on a flat surface. Orient the computer to match the image.
    • Locate the battery release switch, as indicated in the image by the red rectangle. Slide the switch from right to left, and remove the battery.
  2. HP Pavilion dv5000 Hard Drive Replacement, Hard Drive: stap 2, afbeelding 1 van 1
    • Locate the hard drive cover. Note that in this image, the RAM cover is still in place.
  3. HP Pavilion dv5000 Hard Drive Replacement: stap 3, afbeelding 1 van 1
    • Remove the two screws securing the hard drive cover.
  4. HP Pavilion dv5000 Hard Drive Replacement: stap 4, afbeelding 1 van 2 HP Pavilion dv5000 Hard Drive Replacement: stap 4, afbeelding 2 van 2
    • Remove the hard drive cover.
    • The hard drive is now accessible.
  5. HP Pavilion dv5000 Hard Drive Replacement: stap 5, afbeelding 1 van 1
    • Remove the two 5.0mm screws securing the hard drive bracket.
  6. HP Pavilion dv5000 Hard Drive Replacement: stap 6, afbeelding 1 van 3 HP Pavilion dv5000 Hard Drive Replacement: stap 6, afbeelding 2 van 3 HP Pavilion dv5000 Hard Drive Replacement: stap 6, afbeelding 3 van 3
    • Slide the hard drive to the right until the edge of the hard drive is flush with the computer frame.
    • Lift the hard drive out of the hard drive bay, left side first.
  7. HP Pavilion dv5000 Hard Drive Replacement: stap 7, afbeelding 1 van 1
    • Remove the hard drive.
    • If you are replacing the hard drive, remove the four additional screws (two on each side) securing the metal shield to the hard drive. Then, remove the shield from the drive.
Conclusie
To reinstall the hard drive and reassemble your device, follow these instructions in reverse order.
Sam Kaplan
253 Reputatie
2 handleidingen geschreven
Cal Poly, Team 21-34, Regan Fall 2010 Lid van Cal Poly, Team 21-34, Regan Fall 2010
CPSU-REGAN-F10S21G34
4 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 18
Altijd: 14,393
