Ga door naar hoofdinhoud
HP Pavilion dv4000 Heat Sink Replacement
Wat je nodig hebt
  1. HP Pavilion dv4000 Heat Sink Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the laptop upside down with the battery compartment facing you.
  2. HP Pavilion dv4000 Heat Sink Replacement: stap 2, afbeelding 1 van 1
    • Slide the battery release latch to the right and hold in place.
  3. HP Pavilion dv4000 Heat Sink Replacement: stap 3, afbeelding 1 van 1
    • Lift the front edge of the battery up and remove it from the compartment.
  4. HP Pavilion dv4000 Heat Sink Replacement, Heat Sink: stap 4, afbeelding 1 van 1
    • Position laptop with heat sink compartment facing you.
    • Locate the one 2x5 mm Torx screw.
  5. HP Pavilion dv4000 Heat Sink Replacement: stap 5, afbeelding 1 van 1
    • Remove the one 2x5 mm Torx screw securing the thermal cover with a #6 Torx screwdriver.
  6. HP Pavilion dv4000 Heat Sink Replacement: stap 6, afbeelding 1 van 2 HP Pavilion dv4000 Heat Sink Replacement: stap 6, afbeelding 2 van 2
    • Lift thermal cover to reveal heat sink.
    • Remove and set aside thermal cover.
  7. HP Pavilion dv4000 Heat Sink Replacement: stap 7, afbeelding 1 van 2 HP Pavilion dv4000 Heat Sink Replacement: stap 7, afbeelding 2 van 2
    • Locate the four screws on each corner of heat sink.
    • Unscrew the four 2x12 mm screws with a #00 Phillips screwdriver.
  8. HP Pavilion dv4000 Heat Sink Replacement: stap 8, afbeelding 1 van 2 HP Pavilion dv4000 Heat Sink Replacement: stap 8, afbeelding 2 van 2
    • Grab sides of heat sink and carefully lift from compartment.
    • Due to adhesive bonding of heat sink to base, wiggling it side to side before lifting might help removal process.
  9. HP Pavilion dv4000 Heat Sink Replacement: stap 9, afbeelding 1 van 1
    • To reapply thermal paste, check out iFixit's guide here.
Conclusie
Ashukang Kima Tabong
222 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 4-2, Catania Fall 2016 Lid van UMass Dartmouth, Team 4-2, Catania Fall 2016
UMASSD-CATANIA-F16S4G2
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 580
