Ga door naar hoofdinhoud
HP Pavilion dv4000 CD/DVD drive Replacement
Wat je nodig hebt
  1. HP Pavilion dv4000 CD/DVD drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the laptop upside down with the battery compartment facing you.
  2. HP Pavilion dv4000 CD/DVD drive Replacement: stap 2, afbeelding 1 van 1
    • Slide the battery release latch to the right and hold in place.
  3. HP Pavilion dv4000 CD/DVD drive Replacement: stap 3, afbeelding 1 van 1
    • Lift the front edge of the battery up and remove it from the compartment.
  4. HP Pavilion dv4000 CD/DVD drive Replacement, Hard Drive: stap 4, afbeelding 1 van 1
    • Orient the laptop with the hard drive panel towards you.
  5. HP Pavilion dv4000 CD/DVD drive Replacement: stap 5, afbeelding 1 van 1
    • Unscrew the two 2x5mm screws with a #00 Phillips screwdriver.
  6. HP Pavilion dv4000 CD/DVD drive Replacement: stap 6, afbeelding 1 van 2 HP Pavilion dv4000 CD/DVD drive Replacement: stap 6, afbeelding 2 van 2
    • Lift the cover up by the tab near the screws.
    • The cover can be removed from the laptop.
  7. HP Pavilion dv4000 CD/DVD drive Replacement: stap 7, afbeelding 1 van 1
    • Grab the hard drive from the sides and slide it away from the connectors.
    • The hard drive should disconnect with light force. If it doesn't easily slide out, ensure there are no cables or obstacles preventing it from moving.
    • Lift and remove the hard drive from the laptop.
    • We did not have a hard drive in our laptop to demonstrate how to remove it.
  8. HP Pavilion dv4000 CD/DVD drive Replacement, CD/DVD Drive: stap 8, afbeelding 1 van 2 HP Pavilion dv4000 CD/DVD drive Replacement, CD/DVD Drive: stap 8, afbeelding 2 van 2
    • Locate the one 2x5 mm screw in the hard drive bay.
    • Unscrew the screw with a #00 Phillips screwdriver.
  9. HP Pavilion dv4000 CD/DVD drive Replacement: stap 9, afbeelding 1 van 3 HP Pavilion dv4000 CD/DVD drive Replacement: stap 9, afbeelding 2 van 3 HP Pavilion dv4000 CD/DVD drive Replacement: stap 9, afbeelding 3 van 3
    • Locate the hole next to the DVD drive release button.
    • Insert a paperclip into the hole to release the DVD drive.
  10. HP Pavilion dv4000 CD/DVD drive Replacement: stap 10, afbeelding 1 van 2 HP Pavilion dv4000 CD/DVD drive Replacement: stap 10, afbeelding 2 van 2
    • Carefully grasp the DVD drive and slide it out.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Nick LaMarche
373 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 4-2, Catania Fall 2016 Lid van UMass Dartmouth, Team 4-2, Catania Fall 2016
UMASSD-CATANIA-F16S4G2
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 13
Altijd: 1,136
