Ga door naar hoofdinhoud
HP Pavilion dv2913cl WiFi receiver Replacement
Wat je nodig hebt
  1. HP Pavilion dv2913cl WiFi receiver Replacement, WiFi receiver: stap 1, afbeelding 1 van 1
    • Begin by locating the smallest panel with one screw attaching it to the laptop computer.
  2. HP Pavilion dv2913cl WiFi receiver Replacement: stap 2, afbeelding 1 van 1
    • Remove the one screw holding the panel down, and the WiFi receiver will be revealed.
  3. HP Pavilion dv2913cl WiFi receiver Replacement: stap 3, afbeelding 1 van 1
    • Remove the two screws that hold down the receiver.
    • Gently slide the chip out of the socket.
  4. HP Pavilion dv2913cl WiFi receiver Replacement: stap 4, afbeelding 1 van 2 HP Pavilion dv2913cl WiFi receiver Replacement: stap 4, afbeelding 2 van 2
    • Remove the two wires labelled AUX and MAIN from the chip.
    • Remember where these were attached previously as it is important for proper functionality after the replacement.
Conclusie
Adam Braga
230 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 2-7, Isaacson Fall 2016 Lid van UMass Dartmouth, Team 2-7, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G7
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 134
