Ga door naar hoofdinhoud
HP Pavilion dv2700 Hard Drive Replacement
Wat je nodig hebt
  1. HP Pavilion dv2700 Hard Drive Replacement, Hard Drive: stap 1, afbeelding 1 van 1
    • To remove the battery, pull the tab to the left and lift the battery from the computer.
  2. HP Pavilion dv2700 Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Using a #0 Phillips Head screwdriver, unscrew the hard drive cover.
    • The screws cannot be removed from the cover.
    • To remove the cover, lift up and to the left.
  3. HP Pavilion dv2700 Hard Drive Replacement: stap 3, afbeelding 1 van 1
    • Using a #0 Phillips Head screwdriver, remove the screws holding the hard drive in place.
    • These are the two screws located on the right side of the hard drive.
  4. HP Pavilion dv2700 Hard Drive Replacement: stap 4, afbeelding 1 van 2 HP Pavilion dv2700 Hard Drive Replacement: stap 4, afbeelding 2 van 2
    • Lift the tab connected to the hard drive in order to remove it.
    • The hard drive may be difficult to remove by grabbing the tab. In this case, use the spudger to gently pry it from the computer.
Conclusie
Jared Opperman
161 Reputatie
1 Handleiding geschreven
Texas Tech, Team 22-6, Rauch Fall 2015 Lid van Texas Tech, Team 22-6, Rauch Fall 2015
TTU-RAUCH-F15S22G6
3 Leden
2 handleidingen geschreven
Één opmerking
Hi, I have a seagate hard drive that was mounted on a hp pavillon dv series computer. I only have the hard disk and I can not find any serial adapter that can be connected to the hard disk connector. I saw on amazon and ebay but I did not find anything. Can you help me? Thank you!
L. S. - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 19
Altijd: 3,073
