Inleiding
This guide will help you replace the wireless card on you HP Pavilion dv2000.
Wat je nodig hebt
Locate and unscrew the single 3.8mm screw holding the wireless card casing in place.
Lift up and remove the wireless card casing.
Gereedschap gebruikt in deze stap:Phillips #00 Screwdriver$5.49
Remove the two 3.8mm screws holding down the wireless card with your Phillips #00 Screwdriver.
Gently pull out your wireless card from its top side to remove it from its holding.
3 andere personen hebben deze handleiding voltooid.
