Ga door naar hoofdinhoud
HP Pavilion dv2000 Wireless Card Replacement
Wat je nodig hebt
  1. HP Pavilion dv2000 Wireless Card Replacement, Wireless Card: stap 1, afbeelding 1 van 2 HP Pavilion dv2000 Wireless Card Replacement, Wireless Card: stap 1, afbeelding 2 van 2
    • Make sure your computer is powered down and unplugged from the charger before removing any components.
    • Locate and unscrew the single 3.8mm screw holding the wireless card casing in place.
    • Lift up and remove the wireless card casing.
    • The 3.8mm screw will remain in the wireless card casing after you unscrew it.
  2. HP Pavilion dv2000 Wireless Card Replacement: stap 2, afbeelding 1 van 2 HP Pavilion dv2000 Wireless Card Replacement: stap 2, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Use a pair of tweezers to remove the three antennas from their sockets.
    • Remove the antennas by the contacts connected to the socket, the crimps connecting the wires and the sockets are delicate and are easily damaged.
  3. HP Pavilion dv2000 Wireless Card Replacement: stap 3, afbeelding 1 van 3 HP Pavilion dv2000 Wireless Card Replacement: stap 3, afbeelding 2 van 3 HP Pavilion dv2000 Wireless Card Replacement: stap 3, afbeelding 3 van 3
    Phillips #00 Screwdriver
    $5.49
    Koop
    • Remove the two 3.8mm screws holding down the wireless card with your Phillips #00 Screwdriver.
    • Gently pull out your wireless card from its top side to remove it from its holding.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Erik Muniz
820 Reputatie
3 handleidingen geschreven
CSU Fullerton, Team 2-3, Bruce Fall 2014 Lid van CSU Fullerton, Team 2-3, Bruce Fall 2014
CSUF-BRUCE-F14S2G3
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 23
Altijd: 2,201
