Inleiding
If you want to install a larger hard drive or if your hard drive isn't working, consider the steps in this guide to remove your current drive.
Onderdelen
Geen onderdelen nodig.
    • Flip your computer over, so that the underside of your computer is facing upward.
      • Make sure your computer is powered down and unplugged from the charger before removing any components.
    • Locate the hard drive casing on the bottom-right corner of your flipped computer.
    • Remove the two 3.8mm screws with your Phillips #00 Screwdriver and carefully lift up and remove the hard drive casing.
      • Screws on hard drive casing will remain in casing after being unscrewed.
  1. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
    Ooit iets gerepareerd? Je bent een genie.
    Deel je reparatie met #ImAGenius
    We zijn allemaal genieën
    • After you lift off the hard drive casing, using your Phillips #000 Screwdriver, remove the two 3.6mm screws located on the right side of the hard drive.
    • Using your fingers, carefully lift the lower right corner of your hard drive until it is removed from its housing.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Erik Muniz
765 Reputatie
3 handleidingen geschreven
CSU Fullerton, Team 2-3, Bruce Fall 2014 Lid van CSU Fullerton, Team 2-3, Bruce Fall 2014
CSUF-BRUCE-F14S2G3
3 Leden
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 2
Afgelopen 30 Dagen: 25
Altijd: 2,693
