Ga door naar hoofdinhoud
HP Pavilion dv1000 RAM Replacement
Wat je nodig hebt
  1. HP Pavilion dv1000 RAM Replacement, Battery: stap 1, afbeelding 1 van 1
    • Shut down the computer.
    • Disconnect all external devices and cables from the computer.
  2. HP Pavilion dv1000 RAM Replacement: stap 2, afbeelding 1 van 1
    • Flip the laptop over.
  3. HP Pavilion dv1000 RAM Replacement: stap 3, afbeelding 1 van 2 HP Pavilion dv1000 RAM Replacement: stap 3, afbeelding 2 van 2
    • Locate the gray sliding tab next to the black bar where the battery is located.
    • Slide the gray sliding tab to the left until you hear a distinct click.
    • The inside edge of the battery should pop up.
  4. HP Pavilion dv1000 RAM Replacement: stap 4, afbeelding 1 van 3 HP Pavilion dv1000 RAM Replacement: stap 4, afbeelding 2 van 3 HP Pavilion dv1000 RAM Replacement: stap 4, afbeelding 3 van 3
    • Grasp the inside edge of the battery.
    • Lift the inside edge of the battery up to detach the battery from the laptop.
    I bought it old but its camera & bluetooth is not working what can be done
    jagannath dey - Antwoord
  5. HP Pavilion dv1000 RAM Replacement, RAM: stap 5, afbeelding 1 van 1
    • Locate RAM access door on the bottom side of the laptop.
  6. HP Pavilion dv1000 RAM Replacement: stap 6, afbeelding 1 van 3 HP Pavilion dv1000 RAM Replacement: stap 6, afbeelding 2 van 3 HP Pavilion dv1000 RAM Replacement: stap 6, afbeelding 3 van 3
    • Locate the two screws holding down the RAM access cover
    • Unscrew the two screws with a size 00 Philips screwdriver.
    • Note: The screws do not detach from the cover.
  7. HP Pavilion dv1000 RAM Replacement: stap 7, afbeelding 1 van 2 HP Pavilion dv1000 RAM Replacement: stap 7, afbeelding 2 van 2
    • Lift up on the screw side of the RAM access cover to remove it.
  8. HP Pavilion dv1000 RAM Replacement: stap 8, afbeelding 1 van 2 HP Pavilion dv1000 RAM Replacement: stap 8, afbeelding 2 van 2
    • Gently pull apart the metal tabs located on both sides of the stick of RAM.
    • The RAM stick should tilt upwards.
  9. HP Pavilion dv1000 RAM Replacement: stap 9, afbeelding 1 van 1
    • Gently lift the the RAM up and out of its seat.
  10. HP Pavilion dv1000 RAM Replacement: stap 10, afbeelding 1 van 1
    • Repeat the previous two steps for the remaining stick of RAM.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Henry OBrien
104 Reputatie
1 Handleiding geschreven
Cal Poly, Team 10-37, Forte Spring 2011 Lid van Cal Poly, Team 10-37, Forte Spring 2011
CPSU-FORTE-S11S10G37
5 Leden
9 handleidingen geschreven
2 opmerkingen
THANKS - YOU'RE AWESOME!!!! Removing the hard drive was the fix it! the HP site never tells you this - imagine.......
marena - Antwoord
I had never dealt with laptop ram before and i used this guide sussusfully to remove the ram from my old HP Pavilliondv6-3055dx laptop. Thanks!
Andrew Lonero - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 16
Altijd: 8,883
