Ga door naar hoofdinhoud
HP Pavilion dv1000 Media Keys Replacement
Wat je nodig hebt
  1. HP Pavilion dv1000 Media Keys Replacement, Battery: stap 1, afbeelding 1 van 1
    • Shut down the computer.
    • Disconnect all external devices and cables from the computer.
  2. HP Pavilion dv1000 Media Keys Replacement: stap 2, afbeelding 1 van 1
    • Flip the laptop over.
  3. HP Pavilion dv1000 Media Keys Replacement: stap 3, afbeelding 1 van 2 HP Pavilion dv1000 Media Keys Replacement: stap 3, afbeelding 2 van 2
    • Locate the gray sliding tab next to the black bar where the battery is located.
    • Slide the gray sliding tab to the left until you hear a distinct click.
    • The inside edge of the battery should pop up.
  4. HP Pavilion dv1000 Media Keys Replacement: stap 4, afbeelding 1 van 3 HP Pavilion dv1000 Media Keys Replacement: stap 4, afbeelding 2 van 3 HP Pavilion dv1000 Media Keys Replacement: stap 4, afbeelding 3 van 3
    • Grasp the inside edge of the battery.
    • Lift the inside edge of the battery up to detach the battery from the laptop.
  5. HP Pavilion dv1000 Media Keys Replacement, Keyboard: stap 5, afbeelding 1 van 1
    • Remove the highlighted screws.
    • After removing the screws, flip the laptop over.
  6. HP Pavilion dv1000 Media Keys Replacement: stap 6, afbeelding 1 van 2 HP Pavilion dv1000 Media Keys Replacement: stap 6, afbeelding 2 van 2
    • Open the laptop.
    • Use the spudger to lift the keyboard.
    • Do not pull the keyboard up and away from the computer, because it is still attached by a ribbon cable.
    • Press the two white clips forward with your fingers and gently pull the ribbon from the clips.
  7. HP Pavilion dv1000 Media Keys Replacement, Media Keys: stap 7, afbeelding 1 van 1
    • Turn the laptop upside-down again.
  8. HP Pavilion dv1000 Media Keys Replacement: stap 8, afbeelding 1 van 2 HP Pavilion dv1000 Media Keys Replacement: stap 8, afbeelding 2 van 2
    • Turn the laptop right-side up. Open the screen and tilt it all the way back.
    • Locate the media keys.
    • Gently lift up the media key strip using the plastic pry tool.
    • If there is too much resistance when prying, stop and search for cause of the resistance. Do not force the media keys.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Tyler Latour
266 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 6-7, Vijaybhaskar Spring 2014 Lid van UMass Dartmouth, Team 6-7, Vijaybhaskar Spring 2014
UMASSD-VIJAYBHASKAR-S14S6G7
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 672
