Ga door naar hoofdinhoud
HP Pavilion dv1000 Hard Drive Replacement
Wat je nodig hebt
  1. HP Pavilion dv1000 Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Shut down the computer.
    • Disconnect all external devices and cables from the computer.
  2. HP Pavilion dv1000 Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Flip the laptop over.
  3. HP Pavilion dv1000 Hard Drive Replacement: stap 3, afbeelding 1 van 2 HP Pavilion dv1000 Hard Drive Replacement: stap 3, afbeelding 2 van 2
    • Locate the gray sliding tab next to the black bar where the battery is located.
    • Slide the gray sliding tab to the left until you hear a distinct click.
    • The inside edge of the battery should pop up.
  4. HP Pavilion dv1000 Hard Drive Replacement: stap 4, afbeelding 1 van 3 HP Pavilion dv1000 Hard Drive Replacement: stap 4, afbeelding 2 van 3 HP Pavilion dv1000 Hard Drive Replacement: stap 4, afbeelding 3 van 3
    • Grasp the inside edge of the battery.
    • Lift the inside edge of the battery up to detach the battery from the laptop.
  5. HP Pavilion dv1000 Hard Drive Replacement, Hard Drive: stap 5, afbeelding 1 van 1
    • With the battery removed, locate the hard drive access panel.
  6. HP Pavilion dv1000 Hard Drive Replacement: stap 6, afbeelding 1 van 3 HP Pavilion dv1000 Hard Drive Replacement: stap 6, afbeelding 2 van 3 HP Pavilion dv1000 Hard Drive Replacement: stap 6, afbeelding 3 van 3
    • Identify the two screws that attach the hard drive access panel.
    • Remove the identified screws with your #00 Philips screwdriver.
    • Lift the left edge of the access panel up and to the right to detach the hard drive access panel from the laptop.
  7. HP Pavilion dv1000 Hard Drive Replacement: stap 7, afbeelding 1 van 1
    • This particular laptop does not contain a hard drive-- yours will.
    • Identify the plastic tab located on the left side of the hard drive.
    • Grasp the tab, gently lift up, and slide the tab to the left to remove the hard drive from the laptop.
    • If you wish to replace your hard drive with another, the hard drive has a metal bracket screwed onto the sides of the casing. Unscrew the bracket from the old hard drive and screw it onto the new hard drive before inserting into the laptop.
Conclusie
4 andere personen hebben deze handleiding voltooid.
John Park
273 Reputatie
2 handleidingen geschreven
Cal Poly, Team 10-37, Forte Spring 2011 Lid van Cal Poly, Team 10-37, Forte Spring 2011
CPSU-FORTE-S11S10G37
5 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 30
Altijd: 12,164
