Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Shut down the computer.
Disconnect all external devices and cables from the computer.
Locate the gray sliding tab next to the black bar where the battery is located.
Slide the gray sliding tab to the left until you hear a distinct click.
The inside edge of the battery should pop up.
Grasp the inside edge of the battery.
Lift the inside edge of the battery up to detach the battery from the laptop.
With the battery removed, locate the hard drive access panel.
Identify the two screws that attach the hard drive access panel.
Remove the identified screws with your #00 Philips screwdriver.
Lift the left edge of the access panel up and to the right to detach the hard drive access panel from the laptop.
Identify the plastic tab located on the left side of the hard drive.
Grasp the tab, gently lift up, and slide the tab to the left to remove the hard drive from the laptop.
Locate RAM access door on the bottom side of the laptop.
Locate the two screws holding down the RAM access cover
Unscrew the two screws with a size 00 Philips screwdriver.
Lift up on the screw side of the RAM access cover to remove it.
Gently pull apart the metal tabs located on both sides of the stick of RAM.
The RAM stick should tilt upwards.
Repeat the previous two steps for the remaining stick of RAM.
Locate the small panel below the panel you just removed.
Loosen the one screw in the middle with a #00 Phillips screwdriver. Again, the screw will not fall out of the panel when loosened.
Lift the panel up and out of its slot to remove.
Identify the two connections at the top of the bluetooth card.
Using your fingers, gently pull up on the white clip until it releases.
Remove the black clip in the same manner as the white clip
Locate the two clips on either side of the Bluetooth card.
Using your fingers, press the clips outwards, away from the card until the card pops up.
Grab the card gently from the top and pull the card up and out of the slot.
Remove and set aside all of the highlighted screws in the first picture with a #00 Phillips screwdriver.
Remove and separately set aside all of the highlighted screws in the second picture with a #00 Phillips screwdriver.
Turn the laptop right side up, and open it to reveal the keyboard.
Press the two white clips forward and lift the tape out of the clip.
Locate the MediaKeys. They are the black strip right above where the keyboard was.
Using the spudger, gently pry up the MediaKeys.
Remove the two screws next to the left hinge of the monitor with a #00 Phillips screwdriver.
Keep these screws separate from the other screws you have removed.
Using the spudger, loosen the casing behind the battery and the two sides.
The case should lift easily upwards and outwards towards you if you are facing the battery compartment.
With a firm grip on the CD drive's outer casing, slide it away from the laptop.
