Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
This guide will teach you how to safely take apart your laptop and access the faulty or broken Bluetooth card, in order to repair or replace it.
Wat je nodig hebt
Shut down the computer.
Disconnect all external devices and cables from the computer.
Locate the small panel below the panel you just removed.
Loosen the one screw in the middle with a #00 Phillips screwdriver. Again, the screw will not fall out of the panel when loosened.
Lift the panel up and out of its slot to remove.
3 andere personen hebben deze handleiding voltooid.
