Ga door naar hoofdinhoud
HP Pavilion ZD7000 Wi-Fi Card Replacement
Wat je nodig hebt
  1. HP Pavilion ZD7000 Wi-Fi Card Replacement, Battery: stap 1, afbeelding 1 van 1
    • Begin by turning the laptop over so that you can see the bottom of the computer.
  2. HP Pavilion ZD7000 Wi-Fi Card Replacement: stap 2, afbeelding 1 van 1
    • Slide the battery release switch to the right while simultaneously lifting up the battery.
  3. HP Pavilion ZD7000 Wi-Fi Card Replacement, Wi-Fi Card: stap 3, afbeelding 1 van 2 HP Pavilion ZD7000 Wi-Fi Card Replacement, Wi-Fi Card: stap 3, afbeelding 2 van 2
    • Unscrew the 2 screws from the plate that cover the Wi-Fi card.
    • Remove the cover.
  4. HP Pavilion ZD7000 Wi-Fi Card Replacement: stap 4, afbeelding 1 van 2 HP Pavilion ZD7000 Wi-Fi Card Replacement: stap 4, afbeelding 2 van 2
    • Disconnect these 2 antenna wires (which eventually connect to the monitor) from the Wi-Fi card.
    • For reassembly, note where the black and white cables connect to the card.
    • Release the Wi-Fi card from the laptop by pressing the metal hinges on either end of it.
    • Gently remove the card from laptop.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Shantel
545 Reputatie
6 handleidingen geschreven
Cal Poly, Team 30-37, Garner Spring 2010 Lid van Cal Poly, Team 30-37, Garner Spring 2010
CPSU-GARNER-S10S30G37
4 Leden
2 opmerkingen
Can you upgrade the wifi card?
danoco - Antwoord
is there a replacement I can buy
Braeden Culp - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 19
Altijd: 5,451
