Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Deze stap is niet vertaald. Help het te vertalen
Begin by turning the laptop over so that you can see the bottom of the computer.
Slide the battery release switch to the right while simultaneously lifting up the battery.
Loosen the eight Phillips screws around the plate to remove it.
Remove the nine Phillips screws from the plate covering the fans.
Disconnect the lower fan connector from the motherboard.
Remove the metal plate and lower fan.
Disconnect the upper fan connector from the motherboard.
Remove the four spring loaded screws holding the heat sink assembly to the motherboard.
Slide the heat sink assembly including the upper fan out by pulling it down and left simultaneously.
Begin after removing the battery and fans.
Remove the screws from the outer frame of the laptop.
Remove screws from the battery area, noting the following:
These screws are on oversize clearing holes, but hold other components on the keyboard. It is not recommended to remove them yet.
Two screws secure the optical drive: one in the battery compartment and one in the RAM compartment.
With the screws removed, PUSH the optical drive out through the opening at the BLUE arrow. You will need to remove the drive to access two more screws at the edge of the frame in the opening of the optical drive.
Remove eight screws from the back panel of the laptop.
Using a flathead screwdriver, remove two screws on the left-side panel of the laptop.
Open the laptop so that both the screen and keyboard are in view.
Carefully pry off the frame above the keyboard.
To begin disconnecting the monitor, remove two screws.
Make sure to keep the screen propped up to reduce the amount of strain on the screws as you take them out.
Disconnect the two wires connecting the monitor to the rest of the laptop.
Do not tug on the wires. Just like wall plugs, you need to disconnect them from the actual point of connection.
Remove the screws holding the keyboard to the chassis.
Unplug the wire just below the right screw shown and the small white connector to the left of that screw.
The far end of the keyboard bezel may still be held by two screws that can only be accessed by removing the optical drive (as mentioned in Step 9).
Disconnect the three ribbon cables attached to the motherboard.
See images 2 and 3 for a closer look.
Remove the screws from the motherboard.
There are many different sizes and types of screws here. Make sure you are keeping track of where they all belong.
Disconnect the speaker cables from the motherboard.
Slide out the optical drive if it wasn't removed in Step 9.
Pry the frame off the laptop outwards while simultaneously lifting the motherboard out of it.
You can now carefully remove the entire motherboard.
9 andere personen hebben deze handleiding voltooid.
4 Opmerkingen
this guid is perfect for a new bee to disassemble a laptop.forget about grammer and bullets points.follow the images it is great
Very helpful guide, thanks a lot.
