Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Deze stap is niet vertaald. Help het te vertalen
Begin by turning the laptop over so that you can see the bottom of the computer.
Slide the battery release switch to the right while simultaneously lifting up the battery.
Loosen the eight Phillips screws around the plate to remove it.
Remove the nine Phillips screws from the plate covering the fans.
Disconnect the lower fan connector from the motherboard.
Remove the metal plate and lower fan.
Disconnect the upper fan connector from the motherboard.
Remove the four spring loaded screws holding the heat sink assembly to the motherboard.
Slide the heat sink assembly including the upper fan out by pulling it down and left simultaneously.
3 andere personen hebben deze handleiding voltooid.
