Ga door naar hoofdinhoud
HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement
Wat je nodig hebt
  1. HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement, Front IO Board: stap 1, afbeelding 1 van 2 HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement, Front IO Board: stap 1, afbeelding 2 van 2
    • Turn over the computer and remove the rubber feet.
    • Remove the 8mm Philips screws indicated in red circles with a Philips #0 screwdriver.
    • Use a pry tool and lift the lid.
  2. HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement: stap 2, afbeelding 1 van 2 HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Pry open the casing from the back of the IO panel, as shown in the pictures.
  3. HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement: stap 3, afbeelding 1 van 2 HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement: stap 3, afbeelding 2 van 2
    • Finally, remove the two cables circled in red from the front IO panel.
  4. HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement, Mouse and Keyboard adapter: stap 4, afbeelding 1 van 1
    • Locate a blue USB adapter on the left side of the hard disk compartment.
  5. HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement: stap 5, afbeelding 1 van 2 HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement: stap 5, afbeelding 2 van 2
    • Take off the USB with gentle but firm pressure.
    • This is a single USB adapter for both mouse and keyboard, so you must get a wireless mouse and keyboard pair, or you will have to use the extra USB for the other one.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Kyaw Soe
321 Reputatie
2 handleidingen geschreven
Cal Poly, Team S8-G4, Banghart Fall 2017 Lid van Cal Poly, Team S8-G4, Banghart Fall 2017
CPSU-BANGHART-F17S8G4
4 Leden
5 handleidingen geschreven
4Gids Commentaar
Seems like there might be enough room for a usb 2 port hub/splitter (such as Onvian USB Splitter Cable Male to 2 Female Adapter USB) to add an additional usb dongle (such an RF or Insteon USB)? Can you confirm how much room there are?
thomastranrx - Antwoord
Since it's a year old project, I forgot most of the dimensions, but from my memory, it would be possible since it's located in a little groove that can probably fit a wire or two. (You can see it in step one picture)
Kyaw Soe - Antwoord
Can i purchase this dongle anywhere? Is there any documentation on how to pair?
will - Antwoord
I want to use my keyboard/mouse combo on a different computer. Can I just move the dongle from the Wave to the new computer? Why do I have to remove the red wires?
Thank you!
Laura Ann Smith - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 12
Altijd: 2,449
